Question about Centrios EDW8020 DVD Recorder
Why and how do I finalize a dvd disc when I hit menu, i get the circle with a cross signal. When I hit set up, I can get to the menu showing disc utilities but it's faded out. How can I finalize if I can't access disc utilities?
  • Centrios Master
  • 19,396 Answers
On some circumstances you cannot finalize disk, either if many sessions are opened , or if data stored is nearly taking the whole disk.
Posted on Dec 23, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Http://www.epinions.com/reviews/pr-Centrios_EDW8020_DVD just click the link
This recorder has many firmware problems. The one that is most annoying to me, and is repeatable every time, is that you cannot finalize a disk if you recorded it using the timer. If you try, you end up with a disk that just locks up the firmware
LG DVD recorder RH735T. Page 10 of the manual says to finalize a disc before you can play it on a different unit. But when I record something on a disc, the settings menu will not allow me to finalize
On my Toshiba DVD burners, you need to first open the DVD tray, and while it is open hit the regular menu, then DVD menu, select "FORMAT" from the DVD drop down menu, then "FORMAT MODE", which leads you to the 2 CRITICAL Choices :
1) Video Mode - Which has the DVD recording in "DVD Compatibility Mode" so it is "Compatible" with most other DVD Players
OR...
2) VR Mode- Which says "Editing Possibility mode" (Note you need a "+R DVD "to be able to do editing, at least on my machines.
Obviously you'll close the DVD tray to be ready to record
Finish the DVD, @ "DVD" Menu, & Finalize, or what you need with "VR"
Mar 02, 2014 | LG Televison & Video
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
I have recorded many DVD's with you Centrios EDW8020 it works great however I can not play them back on other DVD players. The disc may not been finalized to finalize them I can not acces Disc Utilities...
Hello Joe,
Most of these DVD recorders are really meant to be recorded and played basically on the same machine... Now if the DVD player (that you wish to play, is an older model that is the problem)
But, as far finalizing place the DVD unto tray... close it...now that menu (using the remote) press it..you should have a menu and top menu (top is settings) the menu is play dvd jump to next scene..in settings an Disc that is not finalized should be able to name it and customize it...note if you have use an DVD+/- R you must format prior to use (finalizing is on this same)
Nov 25, 2010 | Televison & Video
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Philips Magnavox MWR10D6 DVD Recorder Finalize dvd
hit stop go to setup menu pops up scroll down to finalize and hit enter
Jun 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Just purchased - no manual - how do you finalize DVDs so they will play on other DVD players?
Using your remote, hit the function button. Scroll down to setup and right to disc setting. Enter on disc setting. Next screen will show 3 settings. Scroll down to finalize and hit enter. It will ask if you're sure you want to finalize. Enter yes. Remember; once you enter yes, there is no going back.
May 27, 2009 | Panasonic DMR-E55 DVD Recorder
Finalizing
that's because u r in HDD mode. Change drive select to "dvd" , then "functions" will show: "disc setting" to include, disc name, pick menu, select first play, and Finalize.
Jul 17, 2008 | Panasonic DMR-E85H DVD Recorder
I CANNOT FINALIZE DVD
This may be a little late but I just got off the phone with customer support. Once you have recorded the program you need to hit stop twice for the finalizing menu to come up. If you only hit it once you will get the disc menu with no option to finalize!!!
I know that this worked for us, I hope that it works for all of you :)
May 27, 2008 | Televison & Video
How to finalize
i have spent 2 months looking for this answer myself... and at last success! i downloaded the user manual from funai(they made this model) available here: http://www.funai-corp.com/6pdf/om/MWR10D6.pdf on page 38 it instructs you to press setup on your remote, from the drop down menu you need to select disc edit and then select finalize. this aggravated me at first because nothing happens when i hit the setup button, i powered off the unit and hit setup before the disc loaded. this step is not mentioned but is necesary. you cannot finalize a disc after it has loaded to the title menu.
Jul 25, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Centrios EDW8020 DVD Recorder Logo
73 people viewed this question
Top Centrios Televison & Video Experts
Ron Oblinsky
Level 1 Expert
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
