1st time-As soon as you start computer keep mashing as fast as you can (not hold down but constant presses) till you get to advanced boot option screen. There are options to choose from.
You will have to use your arrow keys and enter key (no mouse)
First use the safe mode option.(this is in case you are fighting a virus)
turn off repeat the start with f8 key presses till it gives you the advanced boot option screen again. choose last good configuration option. If it lets you it will take a bit of time to restore do not interrupt it while it is fixing its self.
Here is a picture of what the option screen should look like. Here How to Access the Advanced Boot Options in Windows
Copy all your files and documents to an external storage device. If it is windows XP: Start the computer and the moment you do that, start Tapping F8 Key you shall see Advanced boot option. Select Safe mode with Networking and press enter and next option is to choose the Operating system First will be Windows Xp now you need to select the second one and press enter IF you dont have the second option then we might need a Disk.
For Windows Vista & Windows 7. 1. Copy all your files and documents to an external storage device. 2. Shut down the computer. 3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears. 4. Click "Repair Your Computer" if you are not already on it and then press ENTER 5. choose your country and click OK 6. On the "System Recovery Options Screen" click "Restore Application" which is the last option. 7. Follow the on-screen instructions 8. When prompted, click on "Full Factory Recovery" 9. "Next" 10. Click "Yes" 11. you will notice for a while it seems like nothing is happening, give it some time. 12. After some minutes, recovery will complete and you click "Finish"
run in safemode
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs
Please remember to clean Windows registry using registry cleaner reg in out
The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
if a blue screen pops up with white writing theres something seriously wrong with your laptop a blue screen on a computer is the worst possible thing that could happen apart from the thing actually exploding and can be caused by a wide range of things, my suggestion would be to reinstall windows as it will basically give you brand new computer with no errors
you have to navigate the screen with the arrows and press enter on the option to select it......i would recommend starting up windows in safe mode just incase, let it load, then restart your system by selecting restart in windows.....now all should be fine!! :D
Pls rate this post and let me know if that was what you needed!! :D
Good day.
Usually that problem occur when their was changes made in your laptop maybe settings, or defualt setting before the computer was restarted, that makes the windows react that way or maybe virus infect your laptop. Some problem can be solve in safe mode, but since safe mode cannot be fixed, I think you have to re-install the program, but you have to back-up first all your important files before you fixed it.
Thank you.
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
option1:- choose the option called safe mode. the first option. just log in and stay for a while in there and restart your computer.
option2:- choose the option start up windows normally.
