Question about Sony PlayStation 2 (PS2) Console
PS2 door is broke
The door on our PS2 broke while open (my son tripped on it) and now the PS2 will not work. We tried to pop the door back on with the spring but the PS2 is not reading the discs. Help?
    Scholar:
  • 118 Answers
I'm sorry but you can't do anything now, you need a new PS2. It is configured to run in a cretain way, and by undoing that you can't make it back to where it was in factory.
Posted on Jan 30, 2009
Schylling child's safe my son lost his combination
My sons is 34, 43. If that doesn't work, pry a corner of the door slightly open so you can see the lock on the other side of the door. You'll see 2 metal semi circles keepin it locked. Then turn right until the flat part is facing left, then turn the knob left until the 2nd semicircle's flat part faces left and the door should pop open. Hope that made sense.
Apr 20, 2013 | Schylling Combination Steel Safe
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
My son drove our 1999 318i. when he tried to open the door using the key fob it wont unlock. when he tried using the manual key on the driver's side, the mechanism broke. the car wont open. how do we open...
I don't know that this will work, but try using the key and opening the door at the same time, both sides, this procedure works for locked doors and a dead battery, hope this helps, let me know.
Aug 05, 2010 | 1996 BMW 318
Disc door will not retract
push that mother back in there! my ps2 is exactly opposite, it ejects than quickly retracts back into the ps2, i dont even think there is a solution without cracking the ps2 open
Feb 07, 2010 | Sony PlayStation 2 (PS2) Console
My ps2 reset button is kind of ruined... help!?
The plastic (back part of the) button is likely cracked or broke off.
If you are not sure what you are doing when it comes to opening the console and examining it, it would be best to take it to someone that knows how to make adjustments to a PS2/electrical components. The connector and data ribbons are quite sensitive in the PS2 and if you're not careful, the ribbons or other components might get damaged permanently.... especially if you are touching it without an anti-static/grounding strap.
Jul 07, 2009 | Sony PlayStation 2 Slimline Console
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
PS2 doesn't work
Dear Customer,
Due to the knocking of ps2 by ur son,it might have affected the reading lense of the ps2.so i request u to open the console.you would see another cover covering the lense.open tat too.with the help of tissue just try to wipe out the lense n jus turn on the ps2 without closing anythin to jus check whether everythin is workin..if the dvd works,then arrange back or put back everythin back to it's position..hope this would work...else try calling a service engineer.
please rate this solution if it meets ur needs else choose fixya.Thank you...
Dec 17, 2008 | Sony PlayStation 2 (PS2) Console
PS2 door jammed
hey dont lisen to thos other people i just had the ecsact same problem i gess this is vary comen thats y they made the ps2 miny. what hapend was theres a rond thing insid that thinks the doors shut when its open and open when its shut. what u have to do is pop off thos little covers on the bottom underneth there are 8 scruws.take them out too. then this is wered u think the bottom would come off but insted u have to flip the thing over and take off the top.be carfal cuz u dont want to brake the cored that conects the buttons and the rest of the sitom. then under the cover thers a panal ( it has a yellow cashon sticer on it ignor that its just about some stupid lite.) enyway this cover has 4 littal scuws thake them off and underneth is the door and the stupid rond thing. now all u have to do is open the door all the way then sut it all the way ( you could not shut it befor cuz of the cover) once u do that put it bake together and it shud work.(just to make sher it works befor u put it all back together u can plug it in and try it. it works whith all the covers off.)It worked for me and i hope it works for you
Ps iv used mine about 8 times sinc i fixed it and it works grate.
Jun 11, 2008 | KEIO PS2 Optical Scroll Mouse
Ps2
you were taking apart the ps2 since this is the fat ps2 im supposed to think first since your in the ps2 clean out the dust in it for future problems dust is why people keep throwing out fat ps2s and buying small ones they think its broke but its rather a dust problem clean it out the pute all the bolts in the right place if you dont have certain bolts in the ps2 doesnt start so have all the bolts in if its a ps2 slim try to unbolt all of the top and slide the lift thing in there scould be a little place in the top to just pop it in or bolt it in.... that could be a problem with the ribbon slide it back into the slot hopefully it still works the ribbon is really impotant its like a conector of the top and bottom part of the ps2 if all else fails get a repairman there are youssally reapair people at your local game place bestbuy, eb, gamestop ect.
Jan 01, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2
Hi isolationman,
The screws are covered up by the pads on the bottom and square hole fillers. Take a thin blade knife and pry the squares up to reveal the screws.
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
114 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
