Beeping from car radio when using ipod fm transmitter
Just bought a belkin II FM transmitter for my ipod. can tune it in to the car radio fine but every couple of minutes or so I get an extended beep coming from the speakers. (The sound you normally hear when the radio has lost a signal) I have different frequencies, turning the RDS off and playing with the other radio settings to no avail. Any ideas? thanks
techman
  • 3130 Answers
SOURCE: Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
maklean
  • 1665 Answers
SOURCE: FM Transmitter Problem
Are you sure battery is full?
Posted on Apr 08, 2008
  • 520 Answers
SOURCE: Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
Posted on May 15, 2008
Benimur
  • 6966 Answers
SOURCE: FM Frequency Steps
Appreciate the "Ask Me" and my compliments on the choice of an Onkyo TX-SR605.
Onkyos are not very common in my country. Often, they are imported from the US and since we follow US broadcasting standards, there would be no need for modifications particularly with the tuning steps.
To my knowledge, most manufacturers would be coming up with a single model but with:
  • variations of the firmware to suit the region/country of intended use; or
  • a service menu where the country/region of intended use is selectable; or
  • jumpers/bridges in the logic circuitry.
Simply, this is similar to having the unit with a voltage selector at the back for 120, 220 and 240 or an auto volt 100~240.
As to your concern, pls check:
  • if there is such a feature in the menu to change regional settings (the user manual may have this information);
  • firmware update, but rather than select US, pls select one appropriate for India;
  • a service manual where the logic circuitry would be shown and if there are movable jumpers/bridges for the selection of intended region/country (warranty may be void).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
SOURCE: technika fm in car transmitter
press on/off button again once turned on then should work but instructions would have been handy in first place
Posted on Aug 12, 2008
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Tip
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
Iwave fm stereo transmitter
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Jan 24, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
Tip
How do I Attach my iPod to a Radio in a 2002 Miata
<p> <p>Apple's iPod is a great way to listen to your favorite music in private and comfortable. The transfer of this experience in the private confines of your Miata is a great way to enjoy your music while you drive. Apple recommends a variety of devices that you connect your iPod directly to your Miata radio. Attaching your iPod to the radio in his 2002 Miata is a task Hable accompli given the right materials and installation. <br /> <p><br /> <p>1. Buy a car adapter. Apple recommends a variety of products at a price range and power, the Monster iCar Play Wireless 800 FM Transmitter $ 79.95 Belkin Tune Cast Auto for Live for $ 69.95 in FM Transmitter Griffin Road Trip with Smarts scan for RDS + Power $ 99.95. All products are recommended by Apple, the producer and distributor of iPods and all are available through the online store Apple Auto Accessories.<br /> <p> <br /> <p>2. Attach confirmation that the iPod radio tuner device purchased at the door on your iPod and plug the other end of the device in device port Charger / charger in his 2002 Miata. Depending on the interior options that you selected for your Miata, and the automatic or manual transmission, the device port cigarette lighter / charger is located in the panel below the radio in the glove compartment or center console area between the two banks front. <br /> <p><br /> <p>3. Miata Turn on the radio and choose a radio station with little or no audible sound. Typical among the 90 FM stations are reserved for local stations with low transmission towers, so they are often your best option. <br /> <p><br /> <p>4. Connect your iPod and select the radio through stereo cables to your Miata on your device FM radio tuner. For example, if your radio is tuned to 88.1 Miata, you have radio receiver can be tuned to 88.1. <br />
I need to know how to turn it on...i don't know if its broken or what...cuz i put in new batteries and it won't trun on
1. Open the battery cover on your TuneCast II Mobile FM Transmitter. Install the included AAA batteries and
replace the battery cover.
2. Plug the 3.5mm connector into your iPod player or other portable music device.
3. The AUTO ON feature will power on the FM Transmitter when the unit detects an input signal. Your FM
Transmitter’s “AUTO ON/OFF” feature uses your audio player’s volume level to automatically power on and
off.
For best results, keep your player set at a medium volume level. NOTE: Setting your device volume very
low may cause the FM Transmitter to turn off, even if the audio player is on.
You can also press and hold
both and buttons simultaneously for two seconds to turn on the unit. To turn off the unit, press
and hold both buttons simultaneously again for two seconds.
Mar 03, 2009 | Belkin TuneCast II FM Transmitter
How to hookup an IPOD to a pioneer avh-p6500 car stereo
If your car stero has a stereo audio input connector then you can plug a cable in the headphone on the IPod and the other end of the cable into the stereo audio input on the car stereo.
If you don't have an stereo input on the car stereo then you can buy a FM transmitter that is powered by the car's cigarette socket, connect the IPod to the transmitter, switch on the car radio and tune it to the FM station that matches the FM transmitter.
You can now listen to your IPod from the car radio.
Jan 26, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Belkin TuneCast FM transmitter for samsung t9
I just bought this transmitter and i plugged it into the car and my samsung mp3 player and it will charge the player but you cant hear any music even when i tune it to a vacant radio station.
May 20, 2008 | Belkin TuneCast Auto FM Transmitter for...
54 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
