Question about JVC AV-48WP30 48" Rear Projection Television
Video is all green and squeezed together on the top half and flickers. I cannot make out what is on the screen though.The audio is fine, this started happenning a couple years ago, but I could correct it by just turning on the split screen, then turning it back off, then the tv was fine. Now the screen is like that all of the time no matter what I do. I've tried everything in the menu, although it is hard to read also.
  • totalfx679 Jan 12, 2009
SOURCE: Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Posted on Jun 09, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Posted on Jul 03, 2007
ctf1800
  • 4402 Answers
SOURCE: JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Posted on Jan 31, 2008
C-Dog
  • 84 Answers
SOURCE: RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Posted on Feb 12, 2008
SOURCE: We have an I-Art 48
this is very common.. you need to go here Re: Convergence problems on AV-48WP30 then read what it says. There are 2 chips to be replaced to fix it.
Posted on Jan 15, 2010
How to replace wiper switch 96volvo 960 do I have to pull steering wheel
No, the cover over and under the steering column comes off separately. If I remember right, you just have to pry it a little bit OR there was a screw or two on the bottom (looking up from the floor) that held it in. Then it's just squeezed together with little tabs. The top half comes off and the bottom half comes off. Then you can access the stalks.
Jan 17, 2018 | 1996 Volvo 960
Polaroid TLX-04011C 40" TV Flickering Screen
That problem with ur panel. you can do nothing about it ..
repairtv ca
Jan 15, 2014 | Televison & Video
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
Installing multiport valve.
No, the o ring should not squeeze out. When putting the top and bottom components together....
  1. Make sure surfaces are clean...No lube!!!
  2. Make sure o ring is clear
  3. Install o ring usually on lower half but depends on model
  4. Gently place upper half on lower
  5. Place clamp around the halves (this can be tricky)
  6. If there is a tension spring with the clemps, do not use it yet
  7. Without the spring, insert bolt and start tightening the clamp
  8. The halves should slowly come together
  9. Make sure the halves and band are aligned
  10. Once the top is on the bottom fairly secure, loosen the clamp and re-tighten with the spring this time till the spring is compressed with no gap between the colis on the spring. If you have two tightening clamps, do this at equal intervals.
I dont know the exact model you have, but this is a standard procedure... Good luck..
Jul 11, 2010 | Hayward SAND FILTER, PRO SERIES
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Oct 22, 2007 | Nintendo DS Lite Console
JVC AV-48WP30 48" Rear Projection Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
