Lands Phones Logo
Posted on Dec 23, 2008
Call divert not working
Hi,I work in a busy florist and we have the alcatel 4018/4019 phone.... over the christmas period we will not have anyone in the office and need to divert the phone to an external mobile i have tried the forward option and done the process by the manual but it still does not work.... Can i grab help???
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Dec 23, 2008
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
27563
Points
66
Normally this feature is enabled by the phone co. this allows you to activate and de activate the call divert
so call the phone co and ask them is this feature enabled on your line and what are the codes you use to turn feature on/off
i am referring of course to a single business line and not a pabx environment...i hope this helps in some small way
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
465
Points
Did you find a solution to your call divert problem?
we offer a call divert service which is up to 94% saving on BT's call divert charges.
Please email [email protected] for more information
1helpful
Alcatel troubleshooting
1 (866) 582-3688
alcatel-lucent.com/support/
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
1helpful
How to divert a call to other number
* Settings>call>call divert 1.All voice calls 2.If busy 3.If not answer 4.If out of reach 5.If not available N.B.from the above lists choose anyone that you wanted to use for your divert.
* Activate i) To voice mailbox ii) To other number choose anyone that you wanted to use for your divert. In case if you choose to other number There provide your number that you wanted to divert.
And see whether it's suitable for you or not?
Thanks for using FixYa All the Best!
4helpful
How to divert call 5530
Call - Divert.This feature allows you to divert an incoming call to a landline or to any cellular. This way you don't miss out on any important incoming calls. Calls can be diverted when you are busy, unavailable or travelling. The call can be diverted to any landline or cellular within the service provider's network area. Calls cannot be diverted to a cellular of another service provider.
From your Handset menu -
* go to call Divert/Forward.
* choose the option you want from the following.
* enter the number you want to forward the call to.
Options: You can choose from 4 types of Call Divert services:
1. Call Divert on "not reachable" : Diverts calls automatically to your chosen number when you cannot be reached - such as when your phone is out of network coverage, has a no battery charge or is turned off.
2. Call Divert on "busy" : Diverts calls automatically to your chosen number when your phone is engaged.
3. Call Divert on "all calls" : Diverts all calls to your chosen number. If this option is set, you will not receive any calls on your mobile phone till you have cancel Call Divert "all calls" facility.
4. Call Divert "if no reply' : Diverts calls to your chosen number when you do not answer the phone for a specified number of rings, (you can define the number of rings).
Hope it helped out.Please don't forget to rate me thanks alot..
Hi every time I dial out I get a diverting active message, its annoying can anyone help. Thanks Ian
Check if you have any call diverts activated
If you have call divert option when you are busy you will get this msg
4helpful
2answers
My nokia 3110c shows a message like active incoming call diverts when ever i dial a number what does it mean?
It means that you have set up that incoming calls will be diverted (to your voicemail usually) when your "line is engaged", ie when you talk with someone on the phone.
There are 3 diverts: divert on busy, on not available (switched off or out of range) and on no answer (when you don't answer after a certain period).
Depending on operator, they can be activated or deactivated individually, or all three at the same time. The latter option is bad in my opinion - who needs divert on busy? If the phone is busy, try again in a couple of minutes I say...
Anyway, this message is nothing to worry about.
How do I divert calls on my mobile when I am
*21*<mobile no. where u want to divert>#
where star(*) and hash(#) are available on keypad
to cancle the divert
press
##002#
How do i activate the voicemail on my samsung
Here you go :
CALL NOT ANSWERED *61#
DIVERTS WHEN PHONE IS UNREACHABLE *62#
DIVERT WHEN PHONE IS BUSY *67#
After typed desired code press OK or green button (call). Those codes are valid in GSM networks only.
Oct 07, 2009 • Cell Phones
2answers
LG KE850 prada phone - call divert timings
This is an operator supported feature. You need to punch in this code.
**61*destination*11*nn#[SEND]
destination is the number the calls get diverted to
nn = time in seconds (5/10/15/20/25/30)
This will work if you operator have not disabled this code.
CALL DIVERT- TO MOBILES
Type * 71029 then your mobile number and end with a #
thats the code.
Top Alcatel Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Paul Katynski
Paul Katynski
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
