Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
System failure message
My daughter's computer was running well, When she turned it off. When she started it up again she received a message system failure, immediately backup files, then a ticking noise started and the screen went blank and she has not been able to get back into the computer again. She has tried pushing F10 but it does no good, she cannot get back into the recovery mode. Any suggestions? Is this a hard drive failure? Thanks
  • Linda Lindley Apr 14, 2007
    Thanks for the advice. Unfortunately, it is too late to save the hard drive. So will have to buy a new one for her. We may be able to save some info using your suggestion though. Thanks again..
    President:
  • 2,961 Answers
Yes, the ticking sound is the platelettes or the head trying to park, you may be lucky, if you press F8 on start up and try to get into safe mode, if so select 'last known good configuration' and press enter and if you get runnong back up important documents to cd. You may have to replace the hard drive if no luck with the boot up, but you may be able to rescue some files if when you replace the hard disk use your faulty one as a slsve drive and see if you can copy over your needed documents, good luck
Posted on Apr 11, 2007
  • andrew pester
    andrew pester Apr 11, 2007
    sorry, should have said use your faulty one as a slave drive.
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
How can get inside again in the boot setup of a dell optiplex 170L?
Good Day,
That is quite an easy thing to do.
Immediately you turn on your PC, after displaying the brand (for some PC), the computer dispalys 'press F__ to enter boot setup'. If you can't get to read it, either press F2, F12, F10 or F1 continously after you turn on your system. Then you can make your corrections.
I hope this helps. Thank you for using Fixya.
Jul 23, 2012 | Dell Computers & Internet
Windows has detected a hard disk problem
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope it helps
Apr 14, 2012 | Samsung SpinPoint M8 HNM500MBB 25in 500GB...
Fix error code 67
Error Message
"Data Call Failure
Error Code : 67
Error Code 67 Registration Failure. Your PCS Vision username and/or password may be incorrect. Please try again."
This error message is an example of the error message you might have received. You may find that your computer is running slower than you first got it. After frequent use, you may also have system crashes or even blue screen of death.
We strongly suggest that you run a quick scan for error code 67 for your PC to check and fix the errors.
Buy Now (Only $34.95)
30-Day Money-Back Guaranteed
What Is Error Code 67? One thing you should know is that when you access the Internet, your system will have some access to the recourses of a remote computer. If the name of the particular network cannot be found, error code 67 will show up to your computer screen. And you will not be able to use the resources provide in the network.
Fix Error Code 67 Error Now! How to Fix Error Code 67? Sometimes, Windows error codes also indicate a faulty hard ware in your computer. It could be a hard ware that has not been installed properly. Or it could also be insufficient free space in your hard drive. When you receive error messages like that, you should go and check the condition of your hard drive immediately in case of further damages.
Now that you know what the causes of error code 67 are, you have to learn to fix the relating problems. To do this, you can take a look at the tips below:
  • Remove files you do not need from your hard drive. You might have stored files in your computer like movies, music or images that you have accessed for a long time. If you do not need these files, you should better delete them from yourcomputer. This will ensures the sufficient free space in your hard drive.
  • Uninstall unnecessary software and disable startup programs. If you have some software that you no longer need, uninstall them from your computer. Besides, too much startup programs will hinder the process of starting up of your system. You could check and disable the programs you do not need in startup.
  • Scan your system in a regular basis. If your computer keeps on giving you error messages and your system performs slower and slower, you should pay attention to the safety of your computer. Chances are that your computer has been infected by virus or Trojan that hinder the efficiency.
  • Clean your registry. If the registry of your computer is corrupt, you would also receive irritating error messages. So you should scan your registry, identify and fix all the errors in your registry.
Jan 29, 2012 | Refrigerators
My computer had been infected by a virus a few days ago then I run a full system scan in my computer and deleted all virus infected files then I restarted my computer and log in using my username and...
When you turn on your computer press F8 for the startup options and choose Safe Mode. When the computer enters Safe Mode run another system scan and then restart. If you are unable to enter your account again, try to do a System Restore (Start\All Programs\Accessories\System) to a date before the infection happened and then do another full system scan.
Mar 09, 2011 | Microsoft Computers & Internet
When i start computer first i see bios. and after bios computer says that it has system failur
If you receive the message "Error loading operating system" and before Windows was running normally, you can try to reinstall your OS with the repair option (if you can't access your hard drive then it's hdd failure). If your message appears before boot media is accessed, I would recommend you to reset BIOS settings by following the steps below:44a6f3c.jpg
Sep 06, 2010 | ASUS P4G8X Deluxe GD Motherboard
I can't receive my SMS immediately
I think your mobile's internal antenna is harmed. It is not catching the network properly, so take it to an authorized dealer and get it serviced.
Aug 09, 2009 | Nokia N73 Cellular Phone
System failure
Format the computer its work.
Sep 12, 2008 | Tablets & eReaders
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
