Question about KitchenAid Washing Machines
Tank starts to fill then just stops
I have a kitchen aid washer kawe450vwho,it will start to fill then just stops,it was fine untill last night.is this something that i could fix myself?
  • 71 Answers
If you changed the hoses to no leak hoses change them back
Posted on Dec 24, 2008
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Our Maytag washer started making a noise like metal rubbing on metal. After looking and the bottom of the washer the noise seems to be coming from the pulley that is hooked to the drain hose. The main...
It sounds like it may be a bad pump and you will probably need a new belt. I would recommended calling a service tech this is a fairly difficult job to fix and there may be other things going on that you cannot see. Do not attempt to use the machine until it is checked out.If I can do anything else to help please let me know.
Ken
Mar 18, 2010 | Maytag PAV2300 Top Load Washer
Our washer overflowed last night. no warranty on
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Sep 30, 2009 | Kenmore Washing Machines
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
1988 Jeep Cherokee turns over but won't start
change fuel filter sound like its stopping up .
May 01, 2009 | 1988 Jeep Cherokee
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Washing Machines Logo
42 people viewed this question
Top KitchenAid Washing Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Sal De
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
