I had the same problem, wifi would periodically disconnect, and all my other wifi stuff would work fine. New computer, win8. Tried the updates none of them worked. I fixed it by going into the control panels, then selecting Device Manager, in there goto Network Adapters and click the little arrow so you can see devices there. Then right click the Dell Wireless adapter. Then click on the Power Management tab. Uncheck the box for "Allow the computer to turn off this device to save power". After I did that no more issues.
Same issue with me. I've found the solution. I'm not the most technical person in the world so you won't hear any fancy computer talk during this post (i.e. config, ICP, modem, protocol, IDE ATA/ATAPI, etc).
The problem is with the power saving mechanism for Win8. When the PC is left on and it goes to power saving mode. Part of the 'power saving' is to turn off the networking device. So it still shows the connection, but the device to run it is not turned on. In other words, you have the car, its running fine, but you don't have the keys. To fix it, do the following:
Control Panel>
Under 'Devices and Printers' click on 'Device Manager'
Under Device Manager expand 'Network Adapters' (that means click the little triangle).
Click on 'Dell Wireless'
Go to the Power Management Tab
Uncheck "Allow the computer to turnoff this device to save power"
Reboot computer and enjoy the fine advantages of the World Wide Web!!!
I looked at this setting on one of my computers that actually works, the this setting is unchecked. So this must have happened during the last windows 8 update.
Hope this helps.
SOURCE: how toturn on wireless in dell inspiron 6400
you should have a key on keyboard in lower left corner by windows key that says"FN" then hit "F2" that should do it, if that is not the case then there should be a switch along the edge of machine
SOURCE: Dell Inspiron 6000 Wifi?
Look on the keyboard and see if it has a key with a symbol for a wireless device. If it does, click it with the FN (function) to enable or disable it.
You can also see if there is a switch on the front or sides of the laptop for a wireless device.
Finally, go to start>control panel>system. Access the device manager. Click the plus next to network devices and see if any wireless devices are listed.
SOURCE: i have a dell inspiron 1501 laptop and it keeps
no dear vlc doesnt help for that you have to switch on wifi sygnal through the key. 3rd key from escape key.
thanks for using fixya
SOURCE: Can anybody tell me hoe to turn on the wifi on a
Hello Trev. Part of your frustration is that your model is notorious for being problematic with wifi. Read this link to grasp the nature of the matter, the role Dell is playing, and some excellent drivers that may solve the problem for you. Regards, Joe PS please rate my answer. ty.
http://en.community.dell.com/forums/t/19281026.aspx
Testimonial: "Thanks for your quick response, it was very helpful."
Normally when an operating system is installed, it includes a factory reset on a drive D. To see if you have one, open my computer from the menu to view available drives. D drive should say "recovery" .if it does click on it to view the drive's contents and either click on Setup.exe or something.exe and follow the prompts. If your installation did not include a recovery partition, you may be able to download the version of windows from dell using your product key, Hope this helps
