Question about Whirlpool RF365 Electric Kitchen Range
Getting a error code F3E2
What does code mean
  • 8,197 Answers
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven. This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board. If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe. If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly. I recommend calling a service technician to diagnose and repair this oven failure. If you want to attempt to diagnose and repair this failure yourself, resubmit your question with additional details.
Good luck and please rate FixYa!
Posted on Dec 24, 2008
Whiripool range stove model xfe371lvs oven bake element would not go out
Posted on Apr 28, 2009
F3e displayed on a dishwasher what does it mean
Posted on Dec 08, 2009
2 Suggested Answers
SOURCE: Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Posted on Oct 12, 2009
When i used my washer after 3-4 mins f3 e2 maytag front load washer , changed ntc but still same
I am sorry to hear that you have error code F3E2. I know how upsetting error codes can be. I see here that for your Maytag washer, error F3E2 means there is a water temperature sensor error. Below is to test the error
WATER TEMPERATURE SENSOR ERROR:
1. If the water temperature sensor valve is out of range (23 degrees to 217 degrees F or -5 to 103 degree C) during the water-heating step of the WASH cycle.
Possible causes/procedures
a. Unplug washer or disconnect power
b. Make sure that connections to water heater and CCU (TH2 & HE2 cavities) connectors are not broken or with wires detached, and that connector internal pins are visible.
c. Check continuity from the water heater sensor (black wires to CCU (TH2 cavity) Connector.
d. If the continuity diagnosis failed, the Main Harness must be replaced.
e. Check the resistance of the heating element.
f. Check the resistance of the water sensor.
g. Plug in the washer or reconnect power.
h. Verify the washer operation by running the Diagnostic test.
i. After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
Below is the diagnostic test. I have it in two halves so you can read it best that way.
If you will submit your model number I will be able to help you further.
Nov 25, 2014 | Maytag Washing Machines
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
Error code f3e2
F3 - E2 Oven temperature is too high (Cook mode)
Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes
Nov 14, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven indicator lights flashing F3E2, what does that mean?
look behind thecontrol panal and find the wire diagrame,you may have to remove the back panal.un plug unit first.on the diagrame it has a place were it tell's you what f3e2 mean's.
Nov 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
Whirlpool RF365 Electric Kitchen Range Logo
3,701 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
