Question about Vizio GV47LF Television
No picture audio is fine
Problem was Intermittant, is now completly black screen. When it first started I could hear a Loud buzzing noise. If I turned it of in on the noise would cease.
    Sergeant:
    Novelist:
  • 327 Answers
Its definately the problem of timy components on the main board getting over heated and gone faulty and needs to be checked with a multi meter and replace from the board to make it proper.just check out the capacitors AND IC .on the board and remove and replace the faulty.
Posted on Dec 23, 2008
  • Vizio Master
  • 19,396 Answers
Now you have completely black screen because the TV is on protection mode (diagnostic mode) and does not start.
That means that there is an internal fault, probably a faulty component, a short, or a cold solder joint.
  • Ginko
    Ginko Dec 23, 2008
    A loud buzzing noise may have been caused by a fault, either on the audio board, or on the power supply board inside the TV.
    That was probably caused by a faulty component, a short, or a cold solder joint that started giving the trouble.
    Now theon circuit detected the fault and will prevent tv from starting.
    In this case the TV will stay in standby.
    If the TV instead is completely dead, with no power at all , that means that the PSU is gone.
    In both situations you need to call a technician to fix this.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Sony cybershot audio buzzing
I have the same problem, and cant seem to fix it. I know it has to do with the audio chatching the camera making the noise. Listen, take your camera and turn the function to take a video clip, then listen to your camera. Isnt it making the same noise as you hear on the video clip?
Jul 20, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Vizio GV47LF Television Logo
52 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
