Question about Kenmore 14417 Humidifier
One bottle drains completely before the other one?
We just bought a 14 gallon Kenmore Humidifier and one bottle drains out completey before the other one, is this normal>??
  • Anonymous Mar 26, 2014
    water will not flow into evaporator tray at bottom of unit. Bottle is full but no water will drain
Normal no, common yes. $10 says the right bottle drains first..... If you want to get the other bottle to drain put a shim under the side that is not draining.
Posted on Feb 17, 2009
    President:
  • 2,692 Answers
Maybe. It is the spring preasure on the valve.They don't match. It will always take the water from the valve with the least resistance first.
Posted on Dec 23, 2008
Humidifier model 758.743303. How many gallons of water does it hold? Needing to put water treatment in my water don't know how much water it holds.
Use a container of known capacity, e.g., measuring cup or milk bottle, to fill the humidifier. When full, you can estimate capacity.
Jan 24, 2017 | Humidifiers
Bottles won't drain, seems to be air pressure issue
not understanding how it works will get you that assumption
the full bottle will slowly empty when the water level in which it sits gets low enough for the atmospheric pressure to displace the water and let in an air bubble
That way there is always water for the unit to work
Same principle as the bottled water drink coolers in the office
putting a hole in the bottle and you will have water all over the floor
you need to check the humidity level of the air because if it is too high then the system will not work and so the bottles will not empty--really simple principle
Sep 10, 2017 | Essick Air 4DTS-900 Whole House Digital...
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
When we run the humidifier the waterlevel does not change.
The humidifier and it's tubing may be clogged with calcium deposits and scale. Especially so, if you're using well water or your city's water has high calcium deposits.
Empty whatever water is in the unit and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow it to sit for 30 minutes and then turn the unit ON. Once you feel moisture coming out, allow it to run anoter 10 minutes or so. Then turn the unit OFF and empty the remaining solution (if any is left). Now, flush the system by filling it with Bottled Distilled Water and running it.
For future use, I'd recommend that you use nothing but, Bottled Distilled Water.
Apr 07, 2011 | Vicks V3100 1.2 Gallon Humidifier
When i first got it, it was working grate after 3 days it dosent produce much steam as before u can even smell it
The humidifier may be partially clogged with mineral scale. Especially, if you're using well water. It can be cleaned by running the humidifier with with a 50/50 solution of Bottled Distilled Water and White Vinegar in it. Then flushing it with bottled distilled water through another complete cycle.
In the the future, you may want to use Bottled Distilled Water rather than tap water. It's inexpensive (about $1.00 per gallon) and can purchased at most super markets and pharmacies.
Hope this helps solve your problem.
Mar 02, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Mist coning out leavs white dust all over wood work, why?
More than likely the problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust.
I would suggest that if you're using well water, switch to using bottled spring water or bottled distilled water. But you'll need to flush out your humidifier first. Use a 50/50 solution of White Vinegar and water. Fill the tank about half way and run the humidifier until the tank is almost empty. You may want to do this in a garage, if you have access to one, so that the vinegar odor won't remain in the house. Once this has been accomplished, dump out any of the remaining solution and flush the unit again with bottle spring water or distilled water. That should do the trick
Even if you aren't using well water, since your water supply has a high mineral content. I would strongly encourage you to use bottled spring water or distilled water in the future. By the way, a gallon of Distilled Water cost a lot less than bottled spring water. In my area I can get a gallon of distilled water from CVS Pharmacy or Food Lion for about $1.00.
Good luck. Please let me know if this solved your problem.
Rich
Feb 07, 2011 | Sunbeam Ultrasonic Humidifier
How to refill it
Unscrew and remove the lid on the top of the Blue Plastic Reservoir. It holds 2 gallons of water. I would recommend that you use Bottled Spring Water or Distilled Water, because they don't have a high mineral content, which will help the heater element sleeves last longer. Which means a savings in having to buy replacement sleeves. Which can be purchased from Sears.
Hope this helps. Please let me know.
Rich
Feb 06, 2011 | Kenmore 15123 Humidifier
How do i cleanmy kenmore humidifier 11 gallon quiet comfort?
there is instructions in the manual.here's a link:
https://www.manualslib.com/products/Kenmore-758-17006-3083394.html
Feb 03, 2018 | Kenmore 14410 Humidifier
Kenmore 14-gallon humidifier--only right bottle will drain
I just read the reviews because I am considering buying it, and many owners complained of the same problem. Many people said they tried to fix the problems by leveling the machine, however, one guy said he figured it out: just level the machine slightly toward the REAR and it drains correctly. Try it. I hope he's right, because I'm going to take a chance on this machine and it better work well!!! :)
Mar 27, 2008 | Humidifiers
Kenmore 14417 Humidifier Logo
319 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
