Question about Sony XM-754HX Car Audio Amplifier
CUT WIRES INTO MY AMP !!!
Hi everybody ! I've bought this amp out of order. Into, i can see cut wires but don't know where i can replug them... Can somebody help me ? Many thanks !!
  • GODET David Apr 11, 2007
    Thanks but that doesn't give me electric schema !! A single photo of inside electronic parts will be very good...
  • 944 Answers
Here is the link to the user manual http://esupport.sony.com/US/perl/model-documents.pl?mdl=XM754HX&LOC=3 All the connections and installation wiring are well documented in english and french. Hope this helps - please ask again if you have any problem :)
Posted on Apr 11, 2007
SOURCE:
Speaker wiring diagram for a 08 dodge 2500 truck with 7 speaker infinity
Never have found good wiring diagrams for stereo's. Bought them and color codes didn't match. I have mitchell and alldata at work, they don't match. I wire them in with a volt/ohm meter. I find B+, Then hook ignition the the heater control wire. Ohm out the speakers. Thing is, you have infinity. You'll have to find the amp and cut the speaker wires and patch them there also, first. Just a note.. All speaker wires are twisted/paired wires. Cut the tape back 4 to 6 inches to find them. Another note. The speaker wires from the stereo to the amp will be a set of colors. From the amp to the speakers will be different colors.
Nov 01, 2016 | Dodge Cars & Trucks
Need to know how to re wire some cut wires under my drives seat.
Buy yourself a factory wiring book
Not a Haynes or other manual
They will be too generic & not your
vehicle
Have to try Helm.Com for gm,ford,chry & others
The internet will have your manufactures site,
to get what you need
May have to buy a CD
Won't be cheap, but good info that will help you, won't be
You can go to a local auto shop & have them print just
the parts you need, of the under seat wiring
Oct 02, 2014 | Cars & Trucks
The wires going to the plug that goes in the maf sensor on my 96 Nissan pathfinder are cut in two. can they be spliced or should they be replaced in order for maf to work?if replace CAN SOMEONE WALK ME...
Why would you think wires can't be soldered
& heat shrunk?
Where would you get other wires anyway !
Have to cut them off at a salvage yard & then
still have the splice & solder thing to do
Aug 30, 2013 | 1996 Nissan Pathfinder
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
I've a 2002 chevy silveraldo,4.3,it has the integrated MAF/IAT sensor. what color are the wires that i should hook my Tunesport Performance chip to?
That product won't do a thing
You don't cut into the manufactures expertise &
start changing things, unless your building a race car
You have an 11 year old vehicle
I ask- is it even conceivible to increase mileage,
horse power etc,etc if it was brand new & on a street
driven vehicle? No
Every week we get several questions like yours &
not one product has instructions,that's odd isn't it
Who are you asking these questions to & how would
any but a handful of old time car guys even know what
your referring to?
Jan 25, 2013 | Cars & Trucks
What does a burned out headlight for a dyna fxd look like?
the bulb glass itself usually looks burned with black and/or white distortions on the glass. the bulbs are cheap enough, just replace it with a new one. if it's not it, you'll still have a back up on hand.
Dec 04, 2012 | 2008 Harley Davidson FXD Dyna Super Glide
My ac only blows hot air and wont take a charge
Quick test. Find the receiver drier there should be a sensor on it this is a pressure sensor the compressor will not cut in if low on gas cause the lubricant flows through the system with the gas. Unplug sensor & bridge the wires in the plug. With car running & A/C on your A/C clutch should now cut in. This will test the compressor & clutch but don't leave it bridged or you will destroy the compressor. Otherwise could be switch etc but start with that test. As for not accepting gas I don't know Blockage maybe? bad valve?
Jun 14, 2012 | Cars & Trucks
My amp cuts off every time I turn it on.. even with n without the wires connected!!!! N if I do cut it on the volume is on -7 n cuts off automatically n won't come back on unless I replug n plug it up...
Does the "protect" light turn's on when it shuts off? If it does then theres a problem with your wiring or worse this might be a Thermal Protect. The amp shuts off because its lacking of voltage from your battery & alternator. Post your system so i could help you further.
Apr 11, 2011 | Yamaha Audio Players & Recorders
When i cut the volume up on my radio or turn the bass up the amp cuts off and on
check all wires .... make sure your speaker wires arent in the wrong order or shorting ...
did this just start of was it always going on ... if it just started its probly a short in the wires
Feb 10, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Trying to install triple gauge water oil amps
if I remember right the alternator has a large red wire on the back that goes to the battery ,it goes in it just cut and run two wires to the amp gauge must be the same size as the wire you cut 10 gauge I beleive
Sep 22, 2008 | Measuring Tools & Sensors
Car Audio & Video Logo
49 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
