Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
The oven takes twice or three times as long to cook anything!
For the first few years, the oven would just shut off - or so I thought.  It turns out that there's a small pin that gets pushed in when the door is closed.  However, sometimes it slips into a small hole and doesn't get pushed in, so the oven senses that the door is still open and turns off.  Each time I close the oven door, I have to listen to make sure it comes back on. I can get it to stay on now, and it reaches the correct temperature...but if a cookie recipe says it takes 10  minutes, it takes 25.  If a cake takes 45 minutes, it takes an hour and a half.  It's driving me crazy   Anyone figure this one out?
  • 76 Answers
SOURCE: self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Posted on Dec 13, 2006
SOURCE: How to Dismantle Oven Door to Clean Glass
yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
Posted on Dec 29, 2007
  • 4 Answers
SOURCE: oven door locked
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Posted on Apr 28, 2008
  • 415 Answers
SOURCE: TAKES TO LONG TO PREHEAT
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Posted on Sep 13, 2008
SCGRITS
SOURCE: Can't turn oven off
Over the 2008 Hoildays while baking, our Kitchenaid range (KGSA906PSS) "off" button would not turn off the gas oven portion of the range. The two ways we could turn off the oven was to either set a "stop cooking" timer for one minute or to go the main electical breaker box and cut off the electricity to the the range - either way- not a good way. We called Kitchenaid Customer Service at 1-800-334-6889 and stated the problem. We were concerned that this was a safety issue since we could not turn off our gas oven without resorting to the timer or breaker methods. The warranty for the electronics touchpad is from 2-5 years according to our owners manual. We have had the range since Aug. 2005.
We provided our model #, serial#, date of purchase and answered some other questions. Kitchenaid did determine this to be a safety issue and in doing so, our replacement part and labor will be provided free of charge.
Even if your warranty has expired, I would still call Kitchenaid first since this is a safety issue.
Posted on Jan 08, 2009
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave was cooking, a few seconds later it ceased working
If it's not making a strong buzzing sound or anything out of the ordinary, it's probably the Magnatron. Most of the time that's what I find. It's the "antenna" that creates the microwaves. Some ovens carry a 5 year warranty on that part so I would check your manual. They are very easy to replace most of the time. They usually run about $100-$150.00
Feb 15, 2009 | Microwave Ovens
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Aug 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
