Question about Jl Audio 250/1 Car Audio Amplifier
Help I have a jl audio 250x1 amp was working well but now i have to ground the rca's in order for sound to come out didnt have to before dont know what happened i have to ground the outside of the rca or else only a little bit of sound comes out
    Scholar:
  • 94 Answers
Check the earthing of the amp is adequate. It sounds like the amp is floating without an earth until you earth the rca outer.
Posted on Apr 24, 2007
Jl w7 not loud enough
If your sub isn't loud enough you may want to look into a few things;
1. What type of amp you're using and its output rating
2. The gauge of your power, ground, and speaker wiring
3. The condition and type of enclosure you are using
4. Check to make sure the speaker cables don't touch, because this can cause it to ground itself out and produce little to no sound.
5. Check the RCA connections and make sure they are in order
Aug 31, 2012 | Jl Audio 12W7 Car Subwoofer
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
I have a jl audio 500/1. I had the amp professionally installed. The amp played for 2 days and no it has no sound but the power will come on. what could be the problem. I have new rca jacks, 4 guage power...
Go back to where you got it installed and ask them to fix it.
If you don't want to do that I would recommend going to another good car audio shop and getting them to check it out.
You can test it yourself by hooking up an iPod to it using a Headphone to RCA cable.. test at low volume first.
Dec 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
Have a JL audio slash 500 that isnt putting out any audio... i know the sub is fine. but i noticed the RCA inputs are loose and dont hold the cables very tight.. is this my problem and what can i do to...
Yes it possible that the inputs have been damaged on the circuit board of the amp. If the amp has hi level inputs you could try running a speaker wire input to it and see if it works. You might try another pair of rca cables to.
Aug 20, 2010 | Jl Audio Slash v2 500/1v2 Car Audio...
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 250/1 amp
This could be due to multiple things. First I would run a test light to the speaker leads of the amp as if you were running your speaker...it should light up and blink to the sound of music coming through. If no sound then most likely your RCA cables are bad or input jackets on the amp are loose and be shorting out causing the low light to come on. If you know 100 percent that you bought that amp in good running condition then most likely its something simple like the RCA wires are bad..Hope this kind of helps you out.
Feb 21, 2009 | Jl Audio 250/1 Car Audio Amplifier
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
Rca Connection
You need to check the shield ground on the head unit. The following link will guide you through the test procedure.
Shield Ground Testing
Jun 07, 2008 | Jl Audio 500/1 Car Audio Amplifier
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 250/1 Car Audio Amplifier Logo
88 people viewed this question
Top Jl Audio Car Audio & Video Experts
hoyzee1
Morne Olivier
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
