JVC AV-36D302 36" TV Logo
A
Anonymous Posted on Sep 04, 2012
Green hue on bottom - JVC AV-36D302 36" TV
1 Related Answer
Anonymous
  • 240 Answers
  • Posted on Jan 09, 2009
SOURCE: Green Hue with Pulsating Picture
replace C933 = 1000uf a 16v
MY SONY/WEGA/KDF-E5010 HAS STARTED TURNING ITSELF OFF AFTER SEVERAL MINUTES AND THEN ON AGAIN. IT HAS ALSO STARTED SHOWING A GREEN HUE TO EVERYTHING.
The green screen suggests a problem or bad Optical engine. Most Sony sets have a self check for error codes---set off: with remote: Display, 5, vol down, power(hit the power button)
Space bar was blue but is now green ..there's a green hue when pc is on
use warranty to replace problem with electronic expensive to fix then monitor
There is too much green color, i tried hue - contrase - lite etc. but the color is still green
how do i get the red and green hue back on my olevia 227-s11 tv my screen is blue and brown
I replaced the XL-2400 complete bulb replacement now I have a pink hue at the top of my screen and green hue at bottom of my tv screen
I change the lamp 4 my tv sony vega XL-2400 and I steel send me a signal to change the lamp what can I do 4 setup.
1helpful
Some times the picture gets a green and red hue and the menu turns from green to red ,
HI. this is being caused by a faulty convergence chip that is located on the convergence board. simply replacing this chip or replacing the entire board will fix this issue.
1helpful
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Screen issues
For accurate info,please give model # and mo / yr built off
sticker on back of set..............Let me know ASAP please...T.
Green hue
GO to service mode ,On std by mode press diplay-5-volume plus-power button on remote con.
reduce green drive to balance .For good adjustment you need white picutre .Also reduce brightness to noticeble lavel.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
