Question about Asko W600
Front load washers
I am building a platform for my new front load washer. I will secure the platform to the garage floor, but does the washer need to be secured to the platform by bolting it down? I have a friend who has one and it vibrates and moves on her tile floor so I felt it might be good to bolt it down???
    President:
  • 1,294 Answers
Not advisable to bolt down; for if there is a problem with springs, etc you will not know - for the machine is secure. And serious damage will occur while the machine remains bolted down. Your friend has a problem with her shocks or springs and requires to be looked into.
Posted on Apr 12, 2007
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Washer skates over the floor in fast spin cycle
they make a bracket to secure the washer to the floor,check with dealer were you got the machine
Jul 05, 2010 | Samsung WF328AA Front Load Washer
I just bought a Kenmore front load clothes washer and will have it delivered in a week. I did not buy the base that raises the washer to a more comfortable height. I was thinking of building a sturdy...
A friend of mine built an 18 inch high wooden base to raise his wife's washer & dryer because of her bad back, and he had no trouble with it. Speaking as a carpenter, I would make sure that your base is designed strong enough to hold the weight of both machines plus the water that will be in the washer. Use 3/4 inch plywood for the top of the base, with a 2x4 frame underneath. If it will be sitting directly on a cement floor, use treated lumber to avoid wood rot.
Jun 18, 2010 | Washing Machines
Help!! i want to build my own raised platform for my kenmore washer & dryer. i am unsure as to how deep to make it . by measuring the appliances i would think that 26'' should work. does any one have a...
the plat form should not be any smaller than the bottom of the washer or dryer so long as all the feet are or can bet set on the plat for then it will be up to you as how big you want it
Apr 13, 2010 | Kenmore Washing Machines
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
New front load washer dryer is vibrating badly when drying
Q - My washer keeps moving around n the floor, is there any simple things that I can check ?
A - Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Mar 14, 2009 | Samsung B1245 Front Load Washer
Front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Aug 16, 2008 | Washing Machines
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
144 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
