Which cd(s) can be used to copy a recording on a Pioneer PDR-609
I have had a Pioneer PDR-609 for eight years. From cd to Pioneer gives excellent results. Unfortunately the disc manufacturers keep moving the goalposts, so that on one occasion one particular cd is suitable, another time you merely fire a blank attempting to copy a cd. Has anyone found a cd which is always suitable for copying?
    Sergeant:
    Novelist:
  • 327 Answers
The problem you told that sometime it works and sometime is not due to the faulty cd the cd which you r using for copying is proper its the problem of the device which it too old.the parts in it are gone weak so sometimes the cd is getting detected and sometimes not.just get it serviced /cleaned internally.also check out the lens if its dirty this can occur or the lens needs replacement if its gone weak or got got damaged internally. thanks.
Posted on Dec 23, 2008
  • 19,396 Answers
That is not because one or the other CD is suitable , it is because of dirty lens, clean lens using a cleanerr CD.
  • Ginko
    Ginko Dec 23, 2008
    I quote from you "nfortunately the disc manufacturers keep moving the goalposts" false, is many years that big manufacturer,
    (Philips, TDK, Verbatim, Sony etc.) keep building CDs in the same way, only things that change is maximum speed , that is automatically downgraded by the CD writer.
    "so that
    fire a blank attem pting to copy a cd.": that description fits more with a dirty lens problem.
    Try using a CD cleaner and spraying canned air on the lens. If this still does not work, the lens must be cleaned directly with q tips and isopropyl alcohol.
    Also use good brand CD like the ones above, any will do.
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
Cd recorder says can read disc invalid disc
This may not help but I have found not a single positive review of this product and many vocally negative ones...
http://www99.epinions.com/reviews/pr-KLH_CDR2000_CD_Recorder_Player/_redir_att_abrtd__~1/pp_~1/sort_~date/sort_dir_~des/sec_~opinion_list
Maybe it would be best to give up on it and get a quality CDR-Recorder. I've had my Pioneer PDR-09 for 8 years and it is perfect.
Mar 19, 2011 | KLH CDR2000 2-Disc CD Recorder
CHECK message on Pioneer PDR-555RW display
have a Pioneer PDR-555RW with blinking CHECK message on display after repeatedly open/close operation. I cleaned ... - posted in CD Players
Jul 17, 2010 | Pioneer PD-R555RW CD Recorder
How do you finalize after recording a cd?
What model?
My Pioneer PDR-609 requires pressing the Finalize button; then after it displays the time it would take to finalize it I press Pause and it counts down.
Feb 03, 2010 | Audio Players & Recorders
I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
Jan 31, 2010 | Audio Players & Recorders
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
35 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
