Constant hum from both channels, louder from right Muffled audio from any source from left channel
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
SOURCE: Denon AVR-3802 Front Left and Centre channel not working right
I work at an authorized Denon service center and have repaired lots of Denon receivers including this model. So bare with me, and trust that I really do know what I am talking about.
The first thing you need to do is find out if those two speakers may be at fault. You can do it very easy by disconnecting them and connect two of the known good speakers into the channels that the bad sound is coming from and then connect the suspected bad speakers in where those good speakers were connected to.
If the same speakers still sound bad, you know that you have a couple of bad speakers. I think that it is likely that the speakers are OK, but it is a good idea to make sure.
If the sound from the suspected bad channels is now still bad with the two good speakers, you have an internal amplifier problem or you have a problem on the digital board.
For your sake, I hope it is the amplifier that is giving you this problem, if it is, that can be fixed by a good audio technician.
If the problem is the digital board, you may be in for some real headaches. Not that many audio techs are very good at troubleshooting a digital board, its not their fault, it is just a very difficult job.
In either case, it will need to be looked at by a qualified technician.
I hesitate to tell you this, but the problem sounds like a digital board problem. In some rare cases, a technician with excellent soldering skills can reflow a couple if the memory IC's on the digital board and restore proper operation. If the technician is top notch and isolates the problem to a specific IC on the digital board, they can replace that IC and you are good to go.
But in most cases, the technician will not even bother trying to troubleshoot the digital board because it can take hours of troubleshooting, and just order the board if it is available. Most of them are available from Denon, but they are very expensive. Normally the part alone is $200 to $300 and I have seen many times where it takes months to get it.
You can also send it directly to Denon's factory service center and that will get your unit back much quicker. They have direct access to the boards, where-as the authorized service center must order it thru one of the Denon parts distributors and they do not always have them in stock. so you end up waiting for a long time.
If you need to send it to the Denon factory service, let me know and I will email you a return authorization form, this must be faxed or emialed to Denon with the proper information and then they will fax or email it back to you with the RA number which must be written on the outside of the box before shipping it to them.
I hope that this information wasn't to overwhelming, but if you found it helpful a good rating would really be appreciated. It helps to keep the experts on FixYa motivated and willing to answer the questions people have even it the answer is not very good news.
I received an "inappropriate" rating from somebody who just wasn't happy with the truth, and most people never even bother to rate our answers. But that's another whole subject.
let me know if you need more help.
SOURCE: Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
SOURCE: My very old Denon AV Receiver (DRA-55V) works fine
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
