Question about Bose 901 VI Main / Stereo Speaker
Location for Bose speakers 901
Can I place 901 Bose speakers directely on the floor?
If not Can I use a shelf that is 18 inches distance from the floor?
Thanks in advance for your answer
You could, but the boundary effect of the speaker being on the floor will change how the sound is radiated into the room and therefore make the EQ less effective. Best bet is to try to find some sort of stand (maybe even make one out of wood) that put the 901 at the same height the stand would of that came with the speaker.
The speaker and the EQ are designed and engineered as a system.
Look online, the manual for the 901 shows them hanging from the ceiling also as an option.
Posted on Jan 11, 2009
What is a good placement for the 901 series VI speakers? I've heard the backwall is half the distance to the sidewall
Depends on the shape and contents of the room. Look up "best acoustic placement of speakers" in your web browser. Good Luck!
Nov 14, 2014 | Bose 901 VI Main / Stereo Speaker
What is the best locxation for 901 series v1
Optimal placement of these like speakers of any design will vary depending on room dimensions and your listening distance from them.
A good place to start with them would be the same distance apart from each speaker as they are from the listening position. In that position they should also be placed closer to a rear wall than any side wall, approximately half that distance.
Dec 10, 2010 | Bose 901 VI Main / Stereo Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
Jul 11, 2010 | Bose 901 VI Main / Stereo Speaker
Pioneer SX2300 with no radio recption
try the pioneer in another place and move the antenna to other direction until you receive a signal.
Dec 02, 2009 | Bose 901 EQ1915 Home Equalizer
901's directed to TV
Yes, you can plug your TV directly into the Bose 901 Equalizer, but you will still need to go from the EQ into an amp to drive the speakers. The Bose EQ basically is for the speakers, not the signal coming in to it. Because of the speaker design, the EQ "shapes" the sound to compensate for the speakers. Please rate my answer, thanks.
May 22, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Can I place 901 Bose speakers directely on the floor? If not Can I use a shelf that is 18 inches distance from the floor? Thanks in advance for your answer
You can, but they will sound like **** down there. I recommend stands at least 24 inches tall, placed 24 inches away from wall for sound to reflect. I have mine hanging from ceiling for best sound.
Dec 23, 2008 | Bose 901 VI Main / Stereo Speaker
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
209 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
