I cleaned out underneath the sewing plate already and added lubricant to fix that part but fabric still gets jammed underneath the fabric
SOURCE: Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
SOURCE: Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
SOURCE: When I try to sew my machine jams a little every
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
