Question about Hotpoint Ultima WF860 Front Load Washer
WF860 drum filling with water
My hotpoint WF860 will not drain all of the water away after a 40 degree wash, the clothes at the top are spun but the lower clothes are sitting in a small amount of water.  If I put on just a spin program the drum empties fully of water.  When the washing machine is not being used the drum slowly starts to fill with water!!  help
  • Hotpoint Master
  • 19,396 Answers
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Posted on Dec 23, 2008
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are describing.you would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
get some descaler part No C00090908 that should sort the smell as for the seal you will better off replacing it
Jan 26, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 drum not turning. Belt checked all ok, no error codes it just fills with water and goes through the cycle filling and emptying when it should and the drum stays still. Can someone help?
ours did the same as this........ it needed a new control board after checking everything you have mentioned. it was a couple of years ago and at that time it was a hotpoint part only. but they can be picked up on ebay for around 30-40 quid.
Oct 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Jan 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 stops every time with 1 second to go
This problem is caused by the heating element not working.The machine won`t spin & finish because the machine knows it hasn`t heated the water during the wash programe but clock will still count down.this is what we were told by a hotpoint engineer.the callout charge is £89.98 from hotpoint this includes parts & labour. 27/7/07
Nov 05, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
