Question about Sony NW-A1000 MP3 Player
A1000 not switching on
Hi. During play my player just stopped working. When I try to switch it back on the spinning disc appears for a moment then it switches itself off. The player is 'ticking' when i try this. Any ideas? Thanks.
I had this problem and even bought a new battery for it. that didnt solve the problem.i kept resetting it with no joy. i ended up getting REALLY REALLY annoyed with it and whacked it on the computer desk( quite hard that at first i thought i had broken it) low and behold its working again!my thought was that if it is knackered then whacking it hard is not going to do much harm is it?
Posted on Aug 22, 2007
When you have the player stop working and the 'spinning disk' appears, do not bother pressing the reset button-this only switches the unit off. Try giving the unit a sharp shock by dropping it on a carpeted floor from no more than 9-12 inches or holding the unit in your hand and hitting your leg, again with a sharp hit. What ever is skipping in the unit stops and normal operation is resumed. Try not to break your unit by dropping it or hitting it with too much force!
Posted on May 24, 2007
Try connecting your player to the USB cable to ensure that it is being charged before attempting to turn it on again. You may have to leave it for a short while to get enough charge to start up. Also, try pressing the reset button on the player and see if that makes a difference (You won't loose any songs while doing this)
Posted on Apr 27, 2007
Technika region code
Switch player on.
Open tray (with no disc).
On remote Press Setup.
Then press 1 3 8 9
A new menu screen will appear with some interesting data, including the currently set Region code.
Set the Region to 0.
Press 'OK' on the remote control.
Turn the player off and then back on again, using the remote control.
Aug 31, 2014 | Televison & Video
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
I have a surround sound Zenith model # ZHX313 (vcr,dvd and turner). I turned on the progressive scanner while in menu but now I can't turn it off. I've tried unplugging and also tried holding down the stop...
It's unlikely that you've broken it - you appear to be using the wrong method for switching it off.
Correct instructions for turning Progressive (P) Scan off:
1. Remove any disc from the unit and close the disc tray.
2. Wait for the "NO DISC" message to appear on the display
3. Press and hold the "STOP" button on the front of the unit for at least 5 seconds then release.
The video output should return to the normal setting and "P/SCAN" should disappear from the display on the front of the player.
If you are still unable to switch P/SCAN off, please post back for further assistance.
Regards,
BElectric
Jan 03, 2011 | Zenith ZDX-313 DVD Player / VCR Combo
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a region 1 panasonic DVD S27,I would like to make it a region free dvd player.How do I unlock it.
With no disc in the player and the drawer closed, press stop, stop, setup, then 3,8,8,8,3 and the desired region code, (0 for multiregion). Nothing will appear on screen. Then switch the player off and back on. It should now play discs for any region.
Aug 27, 2008 | Televison & Video
Sony NW-A1000 will not play,
If you get the spinning disc error on your sony nw a1000 it means the hardrive is knackerd.
The hardrive in the sony NW A1000 is a segate ST1.2 6gb and these can be bought off ebay for around £8. If you can't find a 6gb one you can fit an 8gb hardrive BUT your NW A1000 will only use 6gb of it.
If you search on the internet you can find instructions on how to remove the back cover of your NW A1000 which is very easy to do! You then unplug the hardrive (be very careful!) and replace it with the new seagate hardrive. Turn the NW A1000 on and go to the home menu, select "settings", then select "intialize disc" and it will format your new hardrive so that it can work with NW A1000.
Jul 02, 2008 | Sony NW-A1000 MP3 Player
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Sony NW-A1000 MP3 Player Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
