Question about Xerox DocuColor 3535 Copier
Printer shows paper jam I clear all paper the problem is still there
  • oooimstuck May 11, 2010
    What code does it say on the machine, and where is it telling you to clear on the UI display?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
First start by power off the device and unplugging it from the wall. Leave unplugged for about 1 min. and then power back on. If the error is still there, look at the switch, sensor, or actuator in the directed area. Look for a small piece of paper, paper dust covering sensor or an actuator or switch out of place. Clean or reposition as need. Listen to the device, does it try to feed the paper? If it tries to feed the paper but does not clean the feed roller / tires with rubber restorer or a high alcohol cleaner. If this does not work you are looking at a clutch or motor problem. The worst case would be a board.
Posted on Jan 05, 2009
Printer show paper jam. how do I clear it to continue use printer
Open the printer up and remove any stuck pieces of paper. Check in the paper tray as well by removing the tray and looking inside. Remove any pieces of paper you see then reinstall the paper tray. Your printer should come back up with no jams. If it still says jam then cycle the power to the printer to see if it clears. If it does not clear, you still have a piece of paper stuck somewhere inside. If you can't find ANY paper stuck your printer may need to be cleaned.
Nov 08, 2017 | PRINTER Office Equipment & Supplies
My dell printer shows error after I have cleared the paper jam.
Try and check the ink or maybe the paper is scrunched up smooth them out.. If this doesnt work then sorry this all i can do XD
Apr 04, 2013 | Dell 1250c Color LED Laser-Class Printer...
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
My HP photosmart PSC2410 XI printer is showing "clear carriage jam"what should I do?
Points to there being paper stuck in the feed rollers, if you have cleared the jam, there may be a shred of paper still stuck, try to examine and remove.
If it IS fully clear and the indicatiors still show a paper jam, check the feed rollers are making contact with the paper, that the paper detector has not been bent upwards ( fooling the printer into thinking that there is still a jam).
Try rebooting the printer, if the problem still shows, this is a job for a qualfied technician
Mar 31, 2011 | HEWLETT-PACKARD PSC 1610 xi All-In-One...
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam
if you cleared the paper jam an your printer still shows this paper jam, you may try this:
1. after you clear the paper jam, turn off an on the printer.
2. if above advice is not working you may try to look more carefully (with a flashlight maybe) if a small piece of paper is not blocking the paper jam sensor.
3. unfortunately this is a job for a qualify serviceman.
4. in less then 2-3 % of cases is a defective sensor, and must be replace by a serviceman.
Sep 23, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
