Question about Xerox Phaser 7300DN Laser Printer
M-audio bx8a connect to denon receiver
Hi, i'm wondering if it's ok to connect the BX8A to Denon receiver (not preamp) since the speakers are already have amp in it. i want to use it as my front speakers for the surround sound but dont' want to use the preamp since the surround and center speakers will connect to the receiver. Thanks for the help. i'm very appreciate any help.
have a great holiday .
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
M audio studiophile BX8a deluxe has very hot back panel when on after a few minutes
There is a problem with the amplifier internal to the unit, most likely from the main power transformer. Return to the place of purchase, or a service center for repair/replacement.
Jun 27, 2011 | M-Audio Studiophile BX8a Speaker
I have a pair of m-audio bx8a deluxe monitor speakers. I need to know how hook my iPhone up to them or just one of them. I tried using a adaptor and plugging into the trs input but the music is distorted....
The conection you made is not quite right. This is because the TRS (and the XLR) connectors at the back of the BX8a are for balanced signal. You have to use either this cable or connect both middle and ground point of the TRS connector at the ground. In other words the ground from the ipod must be connected with ground AND middle ring of both BX8a and the ring of the ipod must be connected with on BX8a TPS tip and the tip of the ipod must be connected with the other BX8a tip. I don't know if you are familiar with soldering connectors, in this case post me back to make a schematic for you with the connections.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Feb 17, 2011 | M-Audio Studiophile BX8a Speaker
Woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
May 23, 2008 | M-Audio Studiophile BX8a Speaker
BX8A studiophile monitors distortion problem
it could be a loose connection or the cone is cracked inside , the only way to find out is to open and take a look inside ,check the connections , the 2 wires from box to speaker, ALSO CHECK where the cone meets with the magnet , hope this helps AJ
May 14, 2008 | M-Audio Studiophile BX8a Speaker
Hook up pair Bx8a to pc
XLR? not true. gold plated, balanced trs cables have a better sound and actually compliments the bx8's technology. that said, you can get cable that is trs-balanced on one end and rca's on the other. then just get a "Y" right-left rca into a stereo 1.5 cable. easy and cheap. but using xlr's for output? NO. save those for your input MIDI instruments and controllers.
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Xerox Phaser 7300DN Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
