Question about Harman Kardon AVR 240 Receiver
Won't turn on
My HK AVR 240 went through a period of time where it would just shut down while it was in full power mode. It did not go into standby mode and it did not shut off completely, nor did it go into protection mode. Now it will not power on at all. The light around the power switch is amber/green, but the reciever will not go into full power and I am not able to perform a reset.
  • 1 more comment
  • jupperman Dec 27, 2008
    The solution from "classyexpert" is interesting, but the provided link only shows brochures and owner's manuals.
    Can someone advise me on how to replace the fuse for this unit?
    PuerkoNess - thanks for the tip, but as I stated in my original post I am not able to do a reset. If I [ress and hold the power button...nothing happens and tha green/amber light stays on.
  • jupperman Dec 28, 2008
    I tried pressing the power button for a full two minutes and nothing happened.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I doubt if the problem is a blown fuse. If it were so, the unit will not even have the "light around the power switch is amber/green". This then would indicate that power is coming into the HK unit, reaching until the power supply section and is processed/converted to at least provide the necessary voltage to illuminate the "amber/green light". What may be interesting to find out is if the power supply is fully switching on to supply the needed voltage of the other circuitry such as the logic controller, the sound processing, the pre-amp and the amp. What leads me to suspect that even the main logic circuitry is not functional is that you have indicated that "nor did it go into protection mode".
Be what ever case it may be, cold solder or faulty power supply, this of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
  • 916 Answers
I am not sure where you would find the fuse in your model but I have found a picture of what it should look like for you.
http://www.vfmaudio.com.au/images/200ampfuseholderhd.jpg
    President:
  • 2,110 Answers
Check speaker wire connections for shorts at receiver and speaker end
    Genius:
  • 1,913 Answers
Press power button for 10 seconds.
then remove battery from it.clean its both side.
alos remove dust from sots.then try with other battry or refix that battrty.
  • 275 Answers
You need to press and hold power button until the amber green light goes off and system is completely off, then press and hold power button for about 10 secs. untill system comes back on
Posted on Dec 23, 2008
    Sergeant:
    Novelist:
  • 327 Answers
The fuse in the receiver would have blown off so this is happening as u shutoff it directly.just needs fuse replacement. and for further help just check out the manuals http://www.retrevo.com/support/Harman-Kardon-AVR-240-Receivers-manual/id/386bh035/t/2/
thanks.
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
HK 3370 turned into protection mode after pluging in a playing iphone. Happened more than one hour ago but hk3370's power light is still red. How do I get this thing out of the protection mode?
turn unit off using main power button, hold down t-mon and cd buttons at same time as switching main switch on should power up and show reset on the display for a short time then dhould go to standby this has reset unit and should now be ok
Jan 10, 2011 | Harman Kardon HK 3370 Receiver
HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Dan
Apr 06, 2010 | Harman Kardon AVR 240 Receiver
HK AVR25 MKII goes on and off numerous times on cold power up
The relay on the PWR SUPPLY board clicks once when the PWR switch is turned on then 2 to 5 sec. later it clicks again and 'off' it goes.
The small transformer ( standby power) on the board appears to be leaking crud (looks like wood glue) all along one edge.
Can I bypass this relay to see if the power transformer is 'ok'?
Jan 16, 2009 | Harman Kardon AVR 25 MKII
HK AVR130 Standby Button not working
I am experiencing a simular problem; amber light stays on ; no other lighting appears. this occured after leaving the avr in standby mode for a long time. I even tried to reset the unit as stated in the last page of manual after the trouble shooting advice - still no response - good luck!
Sep 18, 2008 | Harman Kardon AVR 130 Receiver
Reciever Powers Down
Hi...
Check ALL your speaker connections at both ends.
What kind of volume are you running it at and what kind of airflow do you have around it>?
Thanks
Aug 25, 2008 | Harman Kardon AVR 235 Receiver
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
Harmon kardon avr 125 shuts down
If you want to fix it:
It must be a contact problem arount the power switch, power cable, fuse or the condensator area.
Maybe you can se a black color on the board.
And checking the solderind points with a magnifyer can help too.
Thats all from that distence.
Nov 11, 2007 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 240 Receiver Logo
164 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
