Question about Sony CMT-RB5 Shelf System
CMT-RB5 - No Sound
When all is working well with my stereo I turn it on. There is one click when the display comes on, and a second click when the sound comes on. The problem is that sometimes when I am listening to music that second click, for the sound, unclicks and I lose the sound. If i turn off the stereo and let it sit for anywhere from 10minutes to an hour it usually will come back when I turn it on again. Recently this second click has not been coming at all rendering my stereo absolutely useless. Is this perhaps a bad or broken circuit or broken fuse? I am at a loss.
    Genius:
  • 1,074 Answers
Your set as a problem in the audio circuit. the audio ic or transistor output needs to replaced.call a tech to do the repairs.good luck.
Posted on Apr 12, 2007
SOURCE:
How to aux to optical connection ?
I am taking you literally, that is, you need RCA Aux ---> Optical (eg TOSlink) conversion. You can get converters, which are $50 or so as the format of the signal is quite different each side
http://www.amazon.com/Menotek-Analog-Audio-Digital-Converter/dp/B0045UWXB0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1323623434&sr=1-1
Aug 11, 2014 | Sony CMT-RB5 Shelf System
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
SONY CMT-RB5; connect a turntable to play LPs
You can connect to any input jack like aux, cd, etc
Nov 30, 2012 | Sony CMT-RB5 Shelf System
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Speakers crackle, then sporadically stop
Sounds like an amplifer fault. Many of these Midi system use a large black IC attached to a metal heatsink. They control both the power amp and pre amp on both channels. When they go wrong they can cause all sorts of effects,
If you can repair things I would look at that. If not get ready for a large bill. If it's the IC some are expensive, it does most of the work!
Jan 25, 2009 | Sony CMT-HP7 CD Shelf System
Sony CMT-NEZ30 no sound, goes to standby
Check your speakers maybe one are about to burn out
Jun 26, 2008 | Sony CMT-NEZ30 Shelf System
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Shuffle
Hello, try the remote control, play mode... Best regards, Arpi
May 11, 2007 | Sony CMT-RB5 Shelf System
Sony CMT-RB5 Shelf System Logo
237 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
