Question about Tally LA650 Matrix Printer
PRINTING ON 12 INCHES CHESHIRE
HI,
I have a problem with a tally LA650+. During the last weeks i was able to print my page in WORD in 11 or 12 inches without any problems, but since 1 week I'm only able to print my pages of 11 inches.
When i tried the 12 inches, it missed the 3 first inches and the last 2.
How i can fixed this problem? Nothing have been changed in my templates in word. Is it possible that the MS office update has "erased" this possibility or do i have to make a update some files?
Louis
I have a problem with the Tally T6100. I want to print a formular which is 12 inches of 33cm. In my... Solve this Problem ยท Tally T2245 Matrix Printer ...
2 Suggested Answers
  • 114 Answers
SOURCE: Not the right format in the settings
In windows-Start menu - Settings -printer & faxes - Select your printer - right click - select server properties - give your desire form name - set your page hight & page width-save the form.
This the procedure to create a new form.
Posted on Feb 01, 2009
I CANT PRINT THE CORRECT SIZE
Hi!
fixed the 203 dpi new head in zebra 105sl printer then 1 week print is correct size to 4x6 inches label but after 15 days its not comming full page print.
pls help to get soultion
thanks / Khokan
Jul 15, 2012 | Office Equipment & Supplies
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
In our office we want the printer tomsupport the paper size 15*12. We create the paper size. but it is not displayed while setting the paper size for printing. Our printer is Tally Genicom 6306
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Jan 08, 2011 | TallyGenicom 6306 Matrix Printer
After creating a new form of size 15 x 12 fanfold in the printer settings option, form is saved but not applied. So after selecting printer in a software, the paper size option of 15 x 12 fanfold does not...
THe T6215 can only print a maximum width of 13.6 inches. If you create a form wider than this Windows will not allow you to select this form within the printer driver as the printer is not physically able to print this wide. Your paper may be 15 inches wide but it is unlikely you will be printing 15 inches, simply create a form whose width is equal to the maximum print width or 13.6 inches. You will then be able to select this form in the printer driver.
Dec 13, 2010 | Tally T6215 Matrix Printer
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
How to divide 12 11/16 inches into 71 3/8 inches?
you will need 5 full planks = 68 1/4 inches and the last board will need to be 3 7/16 inches wide.
Nov 15, 2009 | Freud FT750T Laminate Trimmer
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Oct 29, 2008 | Tally Line Matrix T6100 Printer
Not printing right side of page
Check the page format and margins.
Page format should be A4 or letter. Margins should be set to lower.
Nov 29, 2017 | Lexmark Optra S 1620 Laser Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Tally LA650 Matrix Printer Logo
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
