HCN5529W power on problem
Did you ever find the manual you needed for this set ? I have a power on problem with this set too. My lights blink 11 times and then cycles again. I get the music between the 6th and 7th light. I hear what sounds like a relay click on the 1st, 3rd, and 7th blink. I allowed it to cycle this way for an hour without powering on. Bestbuy said they couldn't fix the set because they couldn't get one board. I've had the TV in my garage for the last 10 months. Now I want to try and fix it somehow. I just saw a service manual on ebay for the hcn5527, which I hope is the same TV without a built in tuner.
    New Friend:
Slinteriors
  • 8617 Answers
SOURCE: power up problem
i will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
Posted on May 07, 2008
  • 17 Answers
SOURCE: Akai plasma tv 5 blinking red lights PDP4298ED
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
Posted on May 08, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
stonephoenix
  • 563 Answers
SOURCE: when we turn the tv on the light just blinks 10 x, but wont t. on
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 18, 2009
lightnbaby
  • 36 Answers
SOURCE: tv tries to come on but just clicks and clicks.
There are 3 capacitors in power supply board, all 1000uF10v.
2 for 5vdc and 1 for 12vdc. replace with best quality 1000uF 25V cap.
do it yourself repair will save you $300
Posted on Nov 16, 2009
When I turn my Panasonic 50 on it would turn itself back off and the red indicator light blinks 11 times, so what is the 11 error code. I could not find it in the manual. modTH50pz700u or TH58pz700u
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 08, 2017 | Panasonic Televison & Video
My panasonic tc-l32c22 power light turns then starts flashing 11 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 17, 2015 | Panasonic Televison & Video
I have a sony trinitron wega 32HS20 when i power it up the standby/timer light blinks 11 times then the picture appears sometimes it will stay on all day and sometimes just a few minutes then it powers off...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 19, 2011 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Broken samsung hcn5529w
its not the cap. its the flyback xformer
Aug 29, 2009 | Samsung HCN5529W 55" Rear Projection...
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
POWER LIGHT BLINKS 5 TIMES
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
Feb 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung HCN5529W 55 in
Dead with H. output short circuit, replacment blows short again
First check power area and repair dry joints then change all high voltage (PF value) capacitors in the horizontal section, this fixed the problem
No power, all standby voltages ok
Replace the guide plus. is located to the side of the tuner
Nov 24, 2007 | Samsung HCN5529W 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
