Question about Flotec Fp0s3200a 01 Plastic Sump Pump 1/2 Hp
Pump not pumping water
My pump was working fine until the temp dropped to single digits and I noticed it not pumping. I unplugged it and now it is raining so I plugged it back in. I sounds like it is on but when I submerge it it does not pump water. The float rises adn it sounds like it is going to work but it does not.
  • rmonica76 Feb 08, 2009
    the same exact thing is happening to me. The pump stopped sucking the water and it sounds like it's working but it's not.
  • 332 Answers
Make sure the outlet is clear of debris so it can pump it out,, if it was trying to pump while frozen it could have broke the impeller, so it sounds like it is working but it isn't, motor running but propeller just sitting still,, time for a pump
Posted on Jun 23, 2009
  • gary miller
    gary miller Jun 29, 2009
    the impeller is probobly broke due to it running in freezing weather could have got ice in it or the line was clogged and just broke it, did you check the line to make sure it was clear?
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
1998 Contour, When it is cold it runs fine. But when it warms up it idles very rough at low RPM. It dies sometimes when at a stop light or even going around corners. When it is acting up like this it...
I notice that you replaced the water pump,Did the car over heat at any time, If it did end you didn,t stop right away when it first happen, It can do real serious damage to the engine, That will give the syptons you are describeing,If you notice that the car starts to use more oil, That is a deffenet sign there was damage done to the engine,That it done damage to the piston rings, Have you changed the thermostat in it? It tell me allso when you stay your temp gauge is not working that the termostat .Might not be functioning(Properly)
End mess up the temp (Sending) unit. If the car is over heating there will be a loss in power,
Nov 07, 2012 | 1998 Ford Contour
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
2003 jeep liberty overheating still. Hello, I own a 2003 jeep liberty 3.7l sport and its been having problems ever since i got it. At first i just had to replace the water pump then i had to replace the...
I had the same problem i change the bottom hose and the water pumps inside came loose replaced water pump....Also it has a bleeder by the top hose by battery get the air out.....
Jun 01, 2011 | 2003 Jeep Liberty
How to take off the water punp
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
Aug 13, 2010 | 2002 Buick LeSabre
No heat in car until its 200rpm then perfect
Low coolant level will cause this condition. Check and fill if necessary. Start simple, if that's not it, let me know.
Dec 22, 2009 | 1998 Jaguar XJ8L
Pump loses presssure when automatic pool cleaner is installed
If you have outtake valves post filter (versus intake pre-filter and motor) you could try choking those down to reduce flow back to the pool but maintain pressure through your pump and filter...
Aug 26, 2009 | Hayward 1HP Super Pump II Inground Pool...
Engine temp and heater temp not right.
Take it to another shop, The water pump doen't hold the Thermostate. The thermostate is in the thermostate housing where the end of the radiator hose is connected to the egine.
There are different thermostate rating to which temprature you'll like your engine running at. Most common would be a 190 thermostate you can get them from 160 up to 220.
As for the water pump you would know if that failed do to over heating or leaking from the weep holes in it.
Bring the truck to another shop and have them flush and Antifreeze if it's never benn done and change the Thermostate to a 180 or 190 and should be done every Two years do to waer and tear. Note the 180 runs cooler then the 190 and so on.
I run mine on 160 since I tow a trailer and the radiator also cools the transmisson oil too. Just for though but you should be fine at 180 or 190.
Good luck and hope this helps.
Apr 23, 2009 | 1999 Chevrolet Silverado 1500
Flotec Fp0s3200a 01 Plastic Sump Pump 1/2 Hp Logo
139 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
cornfuzzle
Level 1 Expert
Mike Raino
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
