Question about Sony STR-DE685 Receiver
Output Hello,I have a sony str-de685 receiver and on the display it says that the speakers r off and I cannot get it to go to channel a or b Ive tried everything and cannot get it to a or b speakers
    President:
  • 948 Answers
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
Posted on Dec 29, 2008
Sony STR-DE685, home stereo, center speaker cuts out, as does left surround. tried everything. Worth fixing? or shitcan it?
It all depends on what's wrong it and if it's worth the price to fix it to YOU, doesn't it? If it's really broken only a tech can look at it and tell you the cost to fix it.
Have you eliminated the individual speakers and cables first? Or looked in the manual?
Mar 19, 2011 | Sony STR-DE685 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
The receiver works ok until the vol is reduced and the right front channel drops out. Increasing the vol usually picks up the dead speaker but it drops out again when the vol is reduced. I've tried...
Make sure the audio level on the left and right channels are balanced. Check the menu for audio levels to adjust and make sure they are not maladjusted. If all levels are adjusted properly then the volume control or volume control circuity may be at fault.
Jun 27, 2010 | Sony STR-DE685 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Heard a pop and receiver now displays "PROTECT." Is that a sign of death for this unit?
a lot ahve relays not fuses check speaker leads are not shorted,at the back make sure the spring clips (speaker wire holders) check the springs under the clip hav't shifted,check speakers(unhook all speakers,then mute
Dec 02, 2009 | Sony STR-DE685 Receiver
Right channel low volume on Sony STR-685
Here you go buddy:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C225335&fes=true&mdl=STRDE685
Sep 20, 2009 | Sony STR-DE685 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
The sound goes off and says "unprotected"
check speaker wire connections on the back of receiver
bare wires should never touch each other or the metal chassis
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Sony STR-DE685 Receiver
STR-DE197 Continuous Auto-Protect
Probably dry joint on an output/regulator chip or a failed output ic.
Jun 29, 2017 | Sony STR-DE197 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Sony STR-DE685 Receiver Logo
152 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
