Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Oven Burners not lighting completely
When the oven is on I look below to check the burners. I see the left side burner completely lit. The right side burner has the ignitor glowing red and a small flame burning at the jet at the small square access hole in the tube, but no flames from the main burner. Any ideas?
  • 3 more comments
  • cfox59 Dec 31, 2008
    How do I get to the orifice opening?
  • cfox59 Jan 02, 2009
    Got it! Replaced the ignitors and poked and prodded every orafice I could find, and viola, back in business. Thanks for the help.
  • Anonymous Jan 03, 2009
    When I turn on the oven, the burners are not going on at full heat. The left one will start up strong but simmer down to a warm little glow in about 20 seconds. Then the right some times will kick up to a med force but the left will go out completely. They are never on together in a cold start. I have replaced the dual thermal gas ct-rl valve but the problem is still there. The oven takes hours to heat and can not hold a 350 temp. Is there any other controller I can get to to fix this poor oven
  • Thomas F. Schneider May 11, 2010
    with a tooth pick if it is clogged,or a small wire. If it is already open then that is not the problem..
    Have you tried cleaning the orface opening of that gas jet?
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Posted on Nov 29, 2009
I just want to reiterate what lajjackson said about this LOW HEAT or VERY SLOW HEAT problem....it is the ignitors. They are on eBay for $30. each.... PB040001 or equivalent. An easy fix if you remove the two screws at the end of the gas tube which allows you to remove the two screws that hold the ignitor in place. THANKS to LAJJACKSON!!!
Posted on Jul 16, 2010
When I turn on the oven, the burners are not going on at full heat. The left one will start up strong but simmer down to a warm little glow in about 20 seconds. Then the right some times will kick up to a med force but the left will go out completely. They are never on together in a cold start. I have replaced the dual thermal gas ct-rl valve but the problem is still there and also change out the thermostat knob assembly. The oven takes hours to heat and can not hold a 350 temp. Is there any other problems I am missing. Marty
Posted on Aug 14, 2009
    President:
  • 2,692 Answers
Fixed ya?
Posted on Jan 02, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
Main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Nov 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
I have an older (1997) GE XL144 Gas oven. The burners light but the oven won't heat. Any suggestions?
IF THE PILOT LIGHT IS LIT BUT THE BURNERS DONT FIRE IT IS PROBABLY THE THERMOSTAT. FREEZE A LARGE OVEN PROOF BOWL FULL OF WATER PLACE IT IN THE OVEN FOR TEN MINS TO COOL THE OVEN TO BELOW ROOM TEMP AND THEN TRY THE OVEN IF IT WORKS FOR A SHORT TIME THEN STOPS CHANGE THE THERMOSTAT
Oct 01, 2010 | GE JGRP17 Gas Single Oven
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Oven out/flat top has hot spot/burners ticking everywhere
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
467 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
