I have panasonic TV model TX28PL1. It was working fine and suddenly today I am unable to start it.The red light is on and when i press keys on remote the light flashes but no audio or video from TV.It is like a dead log
SOURCE: Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
SOURCE: TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
SOURCE: TV does not turn on
You have a short in your unit somewhere or a high voltage problem. The most common problem would be a high voltage failure. If you are not familiar with televisions and their safety this is best left to a repair shop. There is not much in a TV that consumers, unfamiliar with the system, can check. The problem should not cost too much to fix. Check for a shop which has a free estimate or low estimate which will be subtracted from the cost of the repair if you choose to have the unit repaired there. Good luck.
SOURCE: No Audio or Video, blinking power light
Did you ever find anything out about this? I have a pt-53tw53g with the exact same problem, and I've been unable to find out what the three flashes means.
SOURCE: flashing red light and working
i have NV-D60EN model panasonic mini dv camer but when i use to record and play back, its red light falshing for about some second later switching itself off. it does not function any thing so that if you don't mid give me the solution please
yours respectful customer
God bless you !!
I have TX28MK1 and it has just gone into standby mode, red light on, which every way you try to switch it on after 10 seconds it reverts to standby.
