Question about Phase Linear 160W AM/FM/CD Receiver W/ Detachable Face
I have a dvd stuck, it will not play or eject????
It makes a strange sound when you try to eject and then it automatically tries to load the disc and says bad disc and goes back to the radio.
  • Victorinho Mar 23, 2009
    i have the same problem...
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: DVD got stuck
I've seen complaints that there is no manual eject. There is. Unplug. Facing the front of the player, and lifting it up above your head, look under where the disc sits. You will see a number of slits that look like ventilation slits. There is one asymmetrical slit on its own, somewhat towards the front, and somewhat towards the right (if memory serves). The slit is about 3/4 of an inch long. Insert a slotted screwdriver on the extreme right end of the slit (still we're facing the front) side of that slot (a narrow shaft might help, but it doesn't have to go very far in). It should sound like it hits plastic. If not, you may have the wrong slot and you may have shorted things out (I suppose an electrician's plastic screwdriver, or a chopstick shaved into screwdriver shape, would work better). Then slide the screwdriver to the left. You should hear/feel unlatching noises, and the front of the loader should wiggle, and you should then be able to pry it forward (maybe using a screwdriver for leverage) and pull out the disc. When the player dies, it would be nice if it didn't take your--or worse not your--DVD with it.
Posted on Dec 28, 2006
SOURCE: MY 2005 PONTIAC G6 6
yeah dude that happened to me, i put subs in my 05 g6, it supposedly happens when the battery dies or u undo the batter, so i took it too a dealership and they tried making me pay $30 for them to tell me it doesn't work so being the angry person i gave them a few choice words and got out of the nice 30 bucks but they will make u pay for a new stock system for a nice $350 bucks which i told them to go screw themselves and i put the dash kit in so i could read the mpg temp and all that and just put a dvd player in it was better and looks better. and to get ur discs out u pull the stock system out get a screw driver and pliers and start taking the junk apart to get them
Posted on Oct 08, 2008
b_stro804
  • 68 Answers
SOURCE: Tivo won't eject bad DVD.
unplug power. hold the eject button while plugging in the power cable
Posted on Jan 07, 2009
SOURCE: Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Posted on Jan 25, 2009
I have one bundle of Verbatim blank DVD's with printable surface. When I tried to recode it says " insert blank DVD " or it is ejecting automatically. I tried in different writers with new blank disc ,...
this may sound strange but what is the rom's you are trying to use them on as some rom's will not take 8x recording or R - or + and it will say there is no disk and ejecting the disc. and dvd disc only work with dvd drives designed for instant record. most models take data/dvd disc as it can be formated in both formats to record but dvd is just one setting that most dont have.
Oct 18, 2013 | Verbatim 94889 - Datalifeplus 8XdvdR Media...
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
Sony dvd/video combo dvd stuck inside
will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
Apr 29, 2009 | Sony DVP-NS305 DVD Player
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Jul 11, 2008 | Jensen VM9510 Car DVD Player
Sony DVD-RW DW-D56A drive playing up
I am not posting a solution, but may be the same problem.
I have dell inspiron 510m with DVD - RW sony A 56
It had burnt one DVD till now, but it can NOT burn any more DVDs.
I have tried burning using windows XP-SP2, Nero 6, Nero 8, burn my files 3.01 BUT no use. The only thing I got is different error messages.
I changed many types of DVD-Rom, from sony, benq..trying to rule out the storge media itself as source of error, but again no use.
Astonishingly, it works a CD-ROM Burner very well.
Any suggestions?
Jun 19, 2008 | Computers & Internet
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Car Audio & Video Logo
52 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
