SVP CDC-8610 Digital Camera Logo
Posted on Sep 04, 2012
Camera won't turn on
1helpful
Remove the battery from the camera for 15mins, replace the battery then go to the camera's Menu and scroll through the settings to Gate & Time then set the correct Date & time.
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
[email protected]
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
1helpful
Canon powershot SD1300 IS won't turn on, even with fully charged battery
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
1helpful
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
1helpful
I have a new Kodak digital camera C183 & it won't turn on when I plug it in the usb port to transfer pictures to my computer. I downloaded the software on two computers & the results are the same...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Top SVP Cameras Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a SVP Camera Expert? Answer questions, earn points and help others
