Question about Kicker S15L7 Car Subwoofer
Install these how do i install these , i don't understand the 4 connections the + and - with the white dots ?
  • 944 Answers
Here is the link to the user guide and installation guide; http://www.kicker.com/06/tech-support/manuals/manuals/2006/2006%20L7%20Sub%20b01%20WEB.pdf page 2 should tell you what you need to know - if not, please ask again Hope this helps :)
Posted on Apr 11, 2007
When installing new lamp, should ballast be replcaed also?
Is there any noise coming from the cable box? My TV had similar problems, and when I had Comcast change the faulty box, the problem stoped
Jul 02, 2014 | Mitsubishi WD-62327 62" Rear Projection...
Page sskip not working
I really don\'t understand what you mean by skip on the LQ 2180 dot matrix printer... Could you explain further. Waiting for your responds as to helping you resolve this issue.
Regards
Hope to hear from you soon.
Dec 03, 2013 | Epson LQ-2180 Dot Matrix Printer
2007 damon escaper battery wiring diagram
you connect red dots to positive .black dots navigeto.
Sep 26, 2013 | Vehicle Parts & Accessories
I don't know how to use my low beam light on my 91
The small dot is probably for park lights, the big dot for the headlights. For low beams, pull the switch lever towards you, just a light pull, you should hear a click.
May 10, 2012 | 1991 Honda Accord
Can a nissan primera 2005 use dot 3 and dot 4 brake fluid
The standard brake fluid for your car is dot 3. This is the best for your car. Dot 4 is a higher standard brake fluid for newer car makes. I don't see any advantages of dot 4 your 2005' car. Other fact is dot 4 is more expensive than dot 3.
Regards
Aug 23, 2011 | 2005 Nissan Altima
Do not understand what the white spot on dial is for, on the 5600 water sofener.
The white dot you refer to is on the gallon wheel ? Upper right hand corner ??? That dot is the starting point for the gallon counter to read "soft water gallons used". If you turn that dial counter clockwise all the way around to "0", then turn the big main dial on the front...CLOCKWISE ONLY!!! this looks like an oven dial, you'll see that the gallon wheel will turn one complete revolution and end up back where it started, that is, the arrow will be opposite the white dot ! That white dot is critical to achieve the correct capacity recovery, based on how hard the water is and how big the cylinder is.
Dec 09, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
Apr 25, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
What does it mean that my 66 pony has a green dot trany?
the '65/'66 C4, was known as the "Green Dot" C4 & has a different shift pattern to the '67/later C4's.
So your C4 tranny is the green dot which is an UPGRADED option. A better tranny better gears and stronger parts and what not, there was also the white dot tranny that was the cheaper or less performance transmission. As far as i understand the white dot was available for better fuel consumption HAHAHA which no one really cared about in 66 anyways.
In '65/'66 it was something like this:
P - Park
R - Reverse
N - Nuetral
White Dot - Starts in 2nd, automatically shifts to 3rd
Green Dot - Starts in 1st, automatically shifts to 2nd and 3rd
Apr 18, 2010 | 1966 Ford Mustang
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
Apr 11, 2009 | Kicker CVR12 Car Subwoofer
Kicker S15L7 Car Subwoofer Logo
140 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
