I cannot set the convection bake or combination bake temperature above 232 degrees
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
SOURCE: GE #JE1590BC01 will convection & combination, but not microwave
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron.
The diode is a fairly
cheap fix, and the mag will cost more.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
Accessing some components for testing will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
The owner's manual will also tell you how long your magnetron warranty is - it's usually 5 to 9 years.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
SOURCE: GE Profile jvm1090ww 01 SN ZR958136
This is because of the bad magnetron only.Just replace the magnetron and it will be fine.
You can get the replacement part(Part number 1428) from below website
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JVM1090WW01/0432/0123370/10052010/00002?blt=06&prst=&shdMod=
Thank you
SOURCE: GE Profile jvm1090ww 01 SN ZR958136 s Convection
The convection heater is control according to the temperature of the part n 3014 Thermister So this is acting like a temperature sensor and it seem that is giving wrong indication to the control panel and switch off the heater at wrong temperature. So you should replace the thermister. You can find this and all a other parts of your oven in this link.
Part Number: AP2025611 made by GE
SOURCE: ge jvm1790wk convection/microwave oven exterior
The cooktop light is 120V, 40W max., part number WB08X10051.
That's all covered on page 27 of your owner's manual here.
You can find
model number from the tag on the oven or part numbers here.
To replace the inside light, you'd need to remove the oven from the wall, and take off the outer cover.
We're
happy
of our answer.
