Question about HP DeskJet 895cse InkJet Printer
The paper light flashes but there is paper in the machine.
The paper light flashes but there is paper in the machine. Thus, the machine will not print
  • Wardenmom Mar 23, 2009
    When I release the paper, and push the restart button on the printer, the pages shoot out with a symbol on it, usually 1 -3 per page for 30-40 pages until I cut the printer off and shut down the computer. I do believe it is a sensor as it acts like it has aproblem picking the sheet up, but where is it?
    Problem Solver:
  • 15 Answers
There is a paper sensor in the paper tray , it will detect where paper is present or tray is empty. may dust cover the sensor, clean the dust on sensor and check where the sensor is working or not
Posted on Dec 23, 2008
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Problem with HP PSC 1350 All-In-One InkJet Printer
All of the lights flash and it wont print or do anything else. The ink cartriges are new I replaced them right before it happened can you please help?
Feb 04, 2008 | HP PSC 1350v All-In-One InkJet Printer
Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Mar 15, 2007 | Brother HL 5140 Laser Printer
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
HP DeskJet 895cse InkJet Printer Logo
462 people viewed this question
Clive
Clive
