Question about Kenmore 33169 Gas Single Oven
Oven Makes large bang sound when on
I have an older gas oven and just recently a little after we turn on the oven to bake something in it--it makes this really large bang sound, almost like something heavy has fallen over (which is what I thought it was the first time it did that, but then we realized the other night that the noise came from our oven). It only does is ever so often, but so far it hads made the noise three times when we have it on bake. I am worried there is some sort of gas issue.
    Scholar:
  • 121 Answers
Check the floor pan in the oven. It may not be installed correctly. There may be some other parts in a bind. Some part in the oven is warped and is changing shape when the oven heats up. This would take some physical looking into.
Posted on Apr 17, 2009
  • 61 Answers
Hello it is time to have a tech out to change the glow bar for bake. When these parts start to fail they dont get hot enough quick enough.
Posted on Dec 23, 2008
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
My oven is ten yrs old lately when i push bake then start the timer starts counting backwards and the pilot light comes on but the oven does not get hot. sometimes i can slam the door and it will start...
Sounds to me like your oven is a gas oven that uses silicone carbide ignition. When that ignitor gets aged it gets weak and will not open the safety valve. How it works video:
When you bang on the oven the bimetal will open on a weak ignitor. If yours is dim orange that is another sign of a weak ignitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 29, 2011 | Whirlpool Ovens
Making a load bang wnen starting
This could be a delayed ignition, whenever a gas appliance makes a loud bang you should call and have it serviced by an authorized service technician before you use it again. Safety first!
Apr 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Kenmore 33169 Gas Single Oven Logo
344 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
