Question about Dell OptiPlex GX150 PC Desktop
My GX150 is dead!
Everytime I turn on my Dell GX150, a message appears:
"Previous attempts at booting at this system have failed at checkpoint [Vmgr, Aux, Date, CfgP, or HDsk]. For more help in resolving this problem, please note this checkpoint and contact Dell Technical Support."
I went to the Dell Support into another computer. I typed my service tag. Then the links were broken in the next step, and I was unable to solve my problem. (Sorry. I was unable to upload my preview picture).
Then I went to another websites to look for the solution. They told me to press F2 or F5 when it boots and still nothing. I inserted the OS CD and still nothing. I pressed all of the F keys (F1-F12) and still nothing.
I even tried pressing the F8 key to go to the Safe Mode and nothing happened.
Then I wrote to FixYa, they gave me a solution. They told me to check the OS CD to see if it's damaged, and my OS CD is not damaged at all.
Is there anyone who can solve the problem to get my computer to start Windows XP normally?
Thank you.
  • lmorgan916 Feb 25, 2009
    Repeated attempts to boot my Dell Inspiron 4300 cycles to "Press F1 to retry boot"
    I have disconnected all of the power users and reset the connections. I also changed the 3V battery.
    After changing the battery, I received the following: "Performing Automatic IDE configuration" which remains for a few seconds then it
    cycles to the "Press F1 to retry boot"
    Any ideas?
  • Dan rogers
    Dan rogers May 11, 2010
    What exactly do you see when you try to start it? What does it do now. Can you get into bios at all?
    Genius:
  • 1,605 Answers
First of all, GX150 is a PIII with 1GB of memories max.
do you know how to get into the BIOS?
press F2 when you start up the machine. if the BIOS don't come up the first time. shut-down the machine manually and try again.
after you get into the BIOS go though all if the settng and make sure they look OK. (if you have no idea what they are, DOn't change it). and make sure CD is the first boot device. press F10 to save and exit.
insert the cd in the CD tray and startup the machine.
look at the screen, and press enter when the screen tells you boot from the cd.
follow the instruction on the screen and reinstall the OS.
Posted on Dec 23, 2008
    Problem Solver:
  • 6 Answers
I ran across a Dell GX260 that had the same problem. ALL I DID was remove the CMOS battery, shorted the contacts to clear the CMOS, and put in a new battery. I didn't think that would work but I was wrong. Worked like a charm.
Posted on Sep 18, 2009
2 Suggested Answers
SOURCE: how to solve Previous attempts
I get the same problem, and it fails before you even have a chance to get to a disk - this fails in BIOS. My specific instance arises when I install 256MB SDram instead of 192MB. Although this motherboard has had 256MB in it before, it is now refusing to boot with anything other than 128 or 192. (I've tried different 128MB sticks thinking it might be a bad stick)
Posted on Aug 17, 2010
How do I fix this error "Previous attempts at booting this system have failed at checkpoint USB0?
go into bios and disable usb ports it should tell you while its booting up what key to press to get there like f1 or f2
Dec 08, 2012 | Dell Precision Workstation 670 PC Desktop
I keep recieving the message...previous attempts at booting this system have failed at checkpoint(poke).for help resolving thisnproblem please contact dell tech support.
If you made a backup disc use that disc and run the repair files options when you boot up your computer. Sound like one of the files got corrupted on hard drive.
Apr 18, 2011 | Computers & Internet
How to solve Previous attempts at booting at this system have failed at checkpoint [Vmgr, Aux, Date, CfgP, or HDsk].Dell Technical Support OptiPlex GX150 PC Desktop
Hi, sounds like you need to either: restore windows using your windows CD or, try booting in safe mode by pressing the ESC or Del key during bootup. From safe mode you can reset your system to a time before your problem started.
Hope this helps, if not come back to me with full descrition of problem so I can help you further.
Aug 03, 2010 | Dell OptiPlex GX150 PC Desktop
Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Feb 05, 2010 | Dell Dimension 8400 PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
My Optiplex GX150 won't boot
I need more information.
But it sounds like your OS has critical errors, you may need to reformat the drive.
Can you get to the bios menu? (first screen after power switch press an designated F key - look fast for the f key to press)
Once in bios
Possible solution #1
Here is what you do in bios, if you can get to it.
Go to boot order, should be under IDE devices, switch from hard drive to cd, and insert your OS cd and restart.
After xp cd loads, choose format drive, quick format recommended for fast (might want to do it just in case this doesn't work), but full format takes a very long time and is more thorough.
Possible solution #2 (try this first!)
Look on your OS cd for damage on the cd! If it is damaged, you may need to replace it
I must go now, personal message me for more help if desired
Dec 23, 2008 | Dell OptiPlex GX150 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX150 PC Desktop Logo
1,341 people viewed this question
Alun Cox
