Question about Dryers
Fan does not run, light kit still works
Please help with your suggestion on why my ceiling fan stops running. Is there a bad capacitor or a fuse that I need to replace?
The light kit works OK. The fan is made by Harborbreeze
Thanks!
Larry
  • prairiesunri Dec 23, 2008
    I forgot to mention that the fan was wired so that one chain controls the fan, and one chain controls the light kit. The fan was working fine for 2 years and failed.
  • prairiesunri Dec 24, 2008
    Thank you, JSEhandyman! I will try your suggestions.
  • 368 Answers
Hi Larry,
Several possiblities come to mind.
1) Electric motors attract dust and lint; enough can either cause the motor to overheat or just physically clog. Regular vacuuming helps, but you may have to pull it apart to check (de-energize that wiring circuit first).
2. Look for any loose wire connections. If you have a multi-meter, use it to check for continuity between the various wires.
3. Look at the motor for signs of scorching or other physical damage. If the previous two steps don't fix it, you're likely looking for a new/rebuilt motor.
Fixing #1 or #2 are probably within the capabilities of the average homeowner; if #3 is the problem, you probably aren't going to rewind the motor - - you might want to check back here with an update (and feedback?).
Posted on Dec 23, 2008
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Installation:
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Jan 17, 2009 | Hampton Bay 24002 Ceiling Fan
Harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Aug 03, 2008 | Dryers
Fan stopped working
Sorry to give you the bad news, but the fan motor is the major component of the fan and once they go bad it is costly to just repair the motor or replace it. You would actually save more money by purchasing a brand new fan rather than try and repair the motor on the old one. It could also be a fire hazard if you try and keep running the fan because they heat up rather quickly when electrical current is applied and they do not function properly. So if you have a switch that controls the motor and lights, please make sure that the one the controls the motor is off, but can still be able to use the lights.
If you would not mind please rate my help, I would appreciate it. Thanks.
Jul 01, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Breeze ceiling fan not working
We were able to get 3 fans running again by replacing the capacitor which had melted in all 3 fans. On one of the fan's the casing around the motor was extremely hot, which prompted us to act quickly. I suppose the fan had been trying to start itself. We purchased the capacitors at an electrical supplier at a cost of $15 each. We were not able to locate the type of capacitors which came with the fan. I am now looking for replacement capacitors at a lower cost if possible. Does anyoe have suggestions of a reputable online dealer for capacitors at a reasonable cost? I would like to keep some on hand.
Apr 29, 2008 | Aloha Housewares (93645) Ceiling Fan
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
527 people viewed this question
Top Dryers Experts
