Question about Refrigerators
Turn off ice maker/ maytag rsw24a fridge?
Ice maker is making buzzing sound...it is not hooked as it is a backup fridge/freezer. the metal on/off rod seems to be busted and is flimsy. is there a way to just turn off the ice maker altogether?
  • stuff_4_all Mar 14, 2009
    Same deal. GE fridge. Can't figure out how to turn off ice maker. Its making a weird buzzing noise. Owner's manual is useless. Short of unplugging the fridge, does anyone have a fix for this?
MNTECH
  • 1543 Answers
SOURCE: New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Posted on Oct 11, 2008
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Posted on Nov 22, 2008
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Posted on Feb 07, 2009
freetek
  • 5569 Answers
SOURCE: fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
Posted on May 25, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Mbf2256heb maytag fridge My fridge seems to cool properly, but it is making this nearly constant buzzing or grunting sound that stops when you open the freezer (bottom) drawer. Suggestions?
Is you unit hooked up to water because if your unit has an ice maker and not hooked up to water currently, the ice maker will call for water about every 45 mins and cause this noise. To stop this action, lift the bail arm to the off position to avoid or stop this from occurring.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 24, 2013 | Refrigerators
Amana bottom freezer, model abc2037dts, there is a motor noise that goes on for 8 seconds then shuts off, then a few clunks for 2 seconds
Even if you do not have the water hooked up for the dispenser and ice maker, the fridge still makes the sound as if it is filling up the ice maker. If you lift the metal arm beside the ice maker, the sound stops happening because it thinks that the ice bucket is full.
Aug 08, 2010 | Refrigerators
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
We are hearing a sound like a clock buzz every 10 minutes. why
If your frig has a factory installed Icemaker and you never hooked it up to your water in your house, the Ice maker is looking for water. Shut off the ice maker by lifting up the metal arm on the ice maker. or unplug it.
Nov 17, 2009 | Maytag PTB2153G Top Freezer Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Freezer is almost always running....
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Feb 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
733 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
