Question about Panasonic Lands Phones
Blowing fuse on kx-t123211d
I have a kx-t123211d that is blowing the 5amp fuse.This system was working until two days ago and then no power. The fuse was blown, and will blow a new one right away when the power is turned on.
  • Panasonic Master
  • 2,460 Answers
This is a good news/bad news solution. You must have had a LOT of years of trouble free service from the system. The bad news is the switching power supply is dead. It needs to be repaired...or you have a chance to find a 2 amp 24 volt DC power supply and insert it into the remote battery molex connector on the bottom right of the cabinet and it may work.
For everybody's benefit, the 123211d was made in like 1985-1994, so the first number in the serial number is the year and the second letter is the month A-L of manufacture. It could wirk for years, then one day, after a power failure or just turning it off, it would die. It would always be someting in the power supply and not the regulator card below it. We would take an old Key System power supply like an Elgin EAK-1 unit, and feed the battery backup port and it would run for years.
Of course, the best thing to do wiould be replace the cabinet and keep yuur old phones. If your 1232 has 32 Panasonic system phones, and all 12 lines, you're not going to be very happy, but here's a summary of what's available.
If your phones are 70xx or newer sets, you can reuse them in the newer Panasonic systems of TA, TAW, TD, or even the TDA/TDE with limitations. If you happen to have some of the 1232xx or 616xx phones, there may be some issues moving to the newest (current) systems.
The TA/TD 1232 starts at 8x16 and uses expansion cards that are hard to find to expand. You can usually find good deals on those old systems and they work well. I'd avoid a 123211d for the reasons above.
The TA-824 is 8 lines and 24 extensions. It's a current system and the base cabinet is 3x8, They are fairly inexpensive, but the expansion cards (2x8/3x8/0x8) can cost as much as the base system.
The TAW-848 and TDA-50 can have 8 or 12 lines (12 in the 50) and about 20-24 of the existing phones.
Anyway, this is the (long) fast answer to your question. If you have 8 or less lines and 24 or less phones, you can find a reasonalbe replacement and gain Caller-ID by changing out cabinets. If your system is larger, you may be looking at an expensive replacement.
Carl
Posted on Dec 24, 2008
Why does the fuse immediately blow on my power door locks? how to fix this?
You have a short somewhere in the system. Maybe one of the lock actuators or a switch. To test disconnect all locks and switch then replace fuse if don't blow start with driver door and reconnect lock check fuse see if it blew if not reconnect switch active lock check fuse see if ok. Continue with each door separate using same steps until fuse no good you will have found short. Replace shorted part.
Apr 30, 2016 | Cars & Trucks
I soldered all the connections on my stereo system and I keep blowing my 5amp fuses I have the yello wire from the head onto pos + on my then I have the black wire on neg .also my red wire is on neg.
check the wiring as the red wire may be a positive power in wire and if you have it on the negative terminal that would amount to a dead short and that would blow the fuse
consider changing the yellow from the + terminal and putting the red wire there and if it stops blowing fuses the put the yellow wire on to the - ve
if that means that the unit doesn't work then touch it back on the + terminal
if that works the solder it there
Aug 13, 2015 | Cars & Trucks
2010 Mazda 6, room fuse. A few weeks ago, my radio, interior dome lights and power locks all stopped working at the same time. Come to find out the fuse labeled "room" was blown. Replaced it and didn't...
I just had the same trouble in a 02 mazda millennia. found the SHORT.it was in the wiring of the drivers sun visor lights. no kidding, too simple. I hope yours is as easy to fix,,
Aug 22, 2013 | Mazda Cars & Trucks
I have a pro-sound 1000 which keeps blowing plug fuses Can you let me know what fuse should be in the plug as this maybe the problem
The fuse in the power plug is there to protect the cable. The fuse in the plug should be the same as the cable. For instance a 5amp cable should have a 5amp fuse. If the fuse blows all the time the cable could be faulty or there could be an overload in the power supply (perhaps the transformer has failed) that is causing the supply to draw more amps than the cable and fuse can cope with.
WARNING fitting a fuse higher than the cable rating could cause the cable to overheat and catch fire!
Mar 07, 2010 | Audio Players & Recorders
I need wiring color code for 97 Ford Expedition
red/yellow leads from the 5amp fuse #29 and red/white leads from 5amp fuse #2. Both of these run into the instrument panel. Let me know if you need more info.
Jan 25, 2010 | 1997 Ford Expedition
Head unit keeps blowing fuse for interior electronics of durango
go for a new fuse
if it is 10A go for 15A
add +5Amp fuse to your present fuse
and then try
Regards
reply by a Vote
Sep 21, 2009 | Alpine CDA-9827 CD Player
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Blown fuse over and over
you need to solder all the connectors and plugs between the 2 boards
Mar 05, 2007 | Toshiba 42H81 42" Rear Projection...
Not turning ON, fuse blows.
In most cases, it is either a shorted component in the power supply or a shorted horizontal output transistor. It will take experienced electronic troubleshooting to fix it. TVs have lethal voltages (both 110V and 25,000V kind) and improper repair can result in shock, injury, or the emission of X-rays by the TV! Be safe and either replace the set or have a shop work on it for you. I'm a tech with over 25 years of experience, by the way. I appreciate honest rating of this reply if you find it helpful.
Nov 13, 2006 | Daewoo DTQ-25S2FC 25" TV
Lands Phones Logo
176 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
