Question about Acer AOpen AW 724 Sound Card
The voice is not clear in both the labtop speaker and the headphone
    President:
  • 2,692 Answers
Here is the download site for your particular sound card. I would suggest reinstalling the firmware and driver for the sound, to see if that fixes the problem.
http://download.aopen.com.tw/Default.aspx
Posted on Dec 23, 2008
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
Dell D810 speakers do not work, but headphone jack does work
It seems as though you might have a bad plug, There is a set of tabs that tell the laptop whether to use the speakers or the headphones. This switch may of locked into the headphones position. This is probably a case of where you would need to replace or repair the headphones port. check to make sure there is nothing in the port to block it. You can also try applying some light oil on the end of a headphones jack and placing it in and out several times to break free a possible stuck part. It also may be a case that the solder mark on the board has disconnected itself from the headphones jack and needs reseating. This would be a difficult fix but not at all impossible.
Apr 26, 2010 | Dell Latitude D810 PC Notebook
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
Sound comes from both speaker and headphone of my compaq c770tu laptop what can i do ?
Do the following:
Unplug laptop cord and remove battery to reset the laptop.
Restart the laptop wint headphone jack IN.
After Windows has restarted with headphone plugged, while windows is on, unplug headphones and restart Windows again with headphones NOT plugged this time.
Aug 15, 2009 | Compaq Presario 700 470024-192 Notebook
Headphone has no voice
do you have the headphone plugged into the right port?
Feb 12, 2009 | Toshiba PA1381U-1ETC Consumer Headphones
Voice in both headphone and laptop speaker so its worthless to us
hi!
You need to adjust a little bit lower in your master volume settings for the microphone. including the master volume.
You can find it at the buttom navigation bar If your're using windows XP. Try to adjust the settings. Your headphone had a mic therefore u need to test it until such time ur speakers will not echo.....
Please reply so that we can diagnose a better option.
Jonags3.
Jan 05, 2009 | Compaq Presario 700 470024-192 Notebook
Cant play voice messages
Is your console set for "Speaker or Headphones or both" in the voice chat settings.
Speaker will come out of the speakers only, if set to headphones it will only come out of those onlyand if set to both it will come out of both.
Cheers
Jun 02, 2008 | Video Game Consoles & Games
Acer AOpen AW 724 Sound Card Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
