Question about HP PhotoSmart 7760 InkJet Printer
Can't change the size of the photo manually when printing
I can't change the size to specific dimensions. I used to be able to, but can't remember how. I can only choose the existing sizes.
Please Help.
    Scholar:
  • 97 Answers
You should try updating the drivers for this device. go to hp.com and lookup the drivers and software. this usually restores all functionality and you can also get a manual there too!
Also you arent required to use the HP software alone, google's free Picasa ap is very powerful and lets you maniputlate images with ease, and will work just fine with this printer. My wife and kids learned it right away. Just look up picasa and you'll find it.
Posted on Dec 23, 2008
Where on my menu do I change the dpi settings on my Canon EOS50D?
You don't.
DPI (dots per inch) is an output specification used when printing a photo, not when taking one.
Any photo editing program will let you change it, but why bother? Instead, simply specify the size of the print you want and the program will compute the required DPI.
Feb 08, 2017 | Cannon EOS 50D Digital Camera
Changing Resolution On A Fuji A350 Camera
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Dec 06, 2007 | Cameras
Ve 2512 printer can adjust machine to print 4x6photo. Print picture on 81/2 /11 only
What photo editing software program are you using? Photo dimensions are usually set in software. You can set what size paper you want in the printer setup section of the printer driver.
Aug 12, 2016 | HP LJ472UTABA Notebook - Elitebook 8460p...
How do I change size of photo that I want to print from my tablet
The size of your print is a function of the software you use to edit and prepare your photo. If you just want to print the photo as is, the size is a function of the printer software. When you click print a box should open with some choices, including the choices for the photo. If you have the instruction manual for your printer, look for the page(s) that describe the photo printing options. Hope this helps.
Mar 03, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
How do I print on A5 paper on my TX300F?
A5 measures 148 × 210 millimeters or 5.83 × 8.27 inches. In PostScript, its dimensions are rounded off to 420 × 595 points.
You should be able to select A5 size in the Epson software, but above is a small idea of the sizes in case you have to setup manually, once you get it setup correctly then save it as a profile in the Epson software.If you are printing A5 then you need to make sure it is in landscape mode (if you are printing more than 1 page) if it is actual A5 sized paper or Photo paper then make sure gauge is moved on printer to the size of the medium being used.
Feb 25, 2015 | Epson TX300F Series
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
How do I change photo print size ? How big a photo print can I make ?
you can print up to size of the paper you have.
A selection of photo sizes should pop up when you use the windows photo viewer and choose 'print'. You could print 5"x7" prints or 8"x10" prints of the same file, for example.
Also, if you have a the right software, you can print poster size prints that are a combination of 8-1/2" x 11" pieces of paper.
This doesn't come standard with windows, though.
Jul 12, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
Picture Size to Large?
This may not be the solution; however, please obtain a larger capacity memory card.
A 2GB card will give you several hundred photos. Cost is less than $10.
You really should not lower the resolution. you will lose detail that you may want in the future (really). (4GB card will hold over 999 pictures - $15)
If you must lower the resolution, press "Menu" and use the arrows to move the highlight bar to "resolution" ... change it to a lower number like 6MP. keep the "FINE" setting in place (if your model has that setting) or maybe "BEST".
Do not use "RAW" - (very large pix).
Hope this helps!
Sep 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Paper size repeatedly returns to "Letter" when I want A4size
go to control panel and choose printer and fax option, right click and select printing preferences. select page setup tab, adjust the paper size to your wanted dimension, then finally click apply and ok. this changes is permanent.
Dec 19, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
HP PhotoSmart 7760 InkJet Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
