Question about Radio Shack VGA PC Camera Webcam
Cannot connect to video device
Can record sound, but will "not connect to video device".
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 31, 2009
Panasonic dmp-bdt220 causes the screen to darken and lighten
It sounds like you have the unit's analog video outputs connected to a TV/Video combo or some time of a recording device. Going through a recording device can cause the image to brighten and darken.
Mar 04, 2014 | Panasonic DMP-BDT220 3D Blu-ray DVD TV
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
Can't see video on preview screen after hitting "start recording". What am I doing wrong.
Hi and Welcome to Fixya,
When there is no video after you hit start recording then go ahead and disconnect your dazzle device to your computer and then connect it back to another usb port. Go to your control panel, system,hardware, device manager and then sound video and games controller look for dazzle device video driver right click uninstall restart your computer afterwards. go back and open Instant DVD Recorder and choose the advance mode. On step number 1 select capture source then select your dazzle device. Open your camcorder play it make sure that the video image will now showing to your preview screen of your computer and then hit record now.
Jan 19, 2010 | Pinnacle Dazzle DVD Recorder
Video is choppy and twice as fast as audio
Disconnect the dazzle and then connect at the back of your computer and then try to this.
Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer Then uninstall your Instant dvd recorder and reinstall it again.
Nov 21, 2009 | Pinnacle Dazzle DVD Recorder
I purchased a dazzle DVD recorder but have the sound cutting out part way through the recording of a video. The sound comes back after rebooting the pc but sometimes cuts out again 30-60 min into a...
Please do this disconnect your dazzle then reconnect at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it together with the audio. Restart your computer. Check also your audio cable connections. Then try it again.
Nov 17, 2009 | Pinnacle Dazzle DVD Recorder
Can I see video through the Instant DVD recorder display?
Yes you can see the video using Instant DVD recorder program. Make sure on step number 1 you choose Dazzle device and then make sure that your vhs,camcorder is connected to your dazzle properly.If ever no video and still no video and no sound please do this. Disconnect your dazzle and then connect at the back of your computer Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. After restarting check and do it again.
Oct 26, 2009 | Pinnacle Dazzle DVD Recorder
I have the pinnacle dazzle dvd recorder, it works great with video, but when I connect de audio cable from my dvd player to the dazzle dvd recorder no audio pass through the device to my computer, any help...
Check your audio device under device manager. By locate this check one.
Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. After you restarting the computer make sure that new hardware found message coming out. After you did that open again your IDVDR or Pinnacle Studio program and then check if the same problem.
Oct 10, 2009 | Pinnacle Dazzle DVD Recorder
Small screen goes blank when I click on "Start Recording" and I get "record error" I am trying to record to hard drive folder
Disconnect your dazzle then connect it again at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Wait for the new hardware found message comes out and then open your IDVDR again and then do the advance mode. On step number1 choose capture source click the pull down arrow and then choose dvc 100. Turn the power on on your camcorder and run it. Make sure that the video image showed on your preview screen. Try record it again.
Sep 28, 2009 | Pinnacle Dazzle DVD Recorder
Interference when recording in NTSC
You need to check your audio and video cable and make sure it is properly connected. Now if you found that there is no problem with your cable that is the time that you need to return the device to your reseller and asked for the replacement
Jul 06, 2009 | Pinnacle Dazzle DVD Recorder
Radio Shack VGA PC Camera Webcam Logo
271 people viewed this question
Top Radio Shack Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
