C200
Do you see dash lights and headlights on when your ignition switch is on position if no check battery volts should be 12.5 volts.if not battery dead have battery checked out get it charged up.if battery dont charge up. it has a dead cell, if battery could be charged up,more likely alternator could be faulty causing dead battery. .
SOURCE: My 2003 mercedes kompressor C200 key is not working!
the key's are special order and they are fairly expensive. Test the voltage in your remote batteries. They should be 3 volts. These systems are very voltage senstive and require a good battery to operate properly. I'm assuming you have the original batteries in the remote now and it is 6 plus years old. These batteries generally last 3 years so it is definatly time if you have not replaced them yet!
SOURCE: How do I reprogramme my keyless remote Mercedes Benz C200
Why not come on a chat with Murphybanton? I will tell u the procedure step by step while we follow it together.
SOURCE: i have a mercedes c200 petrol 1996 model the
have you checked the trans fluid level? It could be trans fluid geting in through a vacuume hose. vacuume modulator on the trans may be bad.
SOURCE: how to make at 0 the maintenance conter for mercedes C200 CDI 99
Switch ignition on
Press trip counter button twice
Switch ignition off
Press and hold trip button while switching ignition on
After 10 seconds new service interval will be displayed +beep
Release trip button
Switch ignition off
Testimonial: "IN the first test it was OK! tanks a lot for your help and best regards"
