Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
FSE1 the code FSE1 shows up on oven when I try to start the self cleaning cycle. when this code shows up, the timer beeps until i push stop.
  • Anonymous Dec 26, 2008
    Same issue, FSE1 pops up when I am trying to clean the oven by using the SELF CLEANING feature. It never locks and starts beeping while flashing the FSE1.
    Beth
localwonder
  • 6784 Answers
SOURCE: code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on Apr 02, 2009
SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Posted on Aug 25, 2007
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
MY REPAIRMAN
  • 61 Answers
SOURCE: F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Posted on Jan 25, 2009
kachbibi1
  • 979 Answers
SOURCE: Stopping the self-clean function after starting in erro
You don't have a cancel clean button on it? If not, you may have a reset button in the back of the oven. Otherwise, you may have to let it "run the cycle". Hopefully, you don't have wooden/plastic handles on your frying pans.
Posted on Jan 30, 2009
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 | Ovens
My oven went thru the self clean cycle then started beeping. E1-F-5 shows on the screen and the door is locked and no matter what I do or push it just keeps beeping. I have unplugged it to make it stop....
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 19, 2011 | Kenmore Ovens
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Jan 19, 2011 | Whirlpool Ovens
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
We have a kenmore model# 911.47692100, oven with a self-cleaning cycle that does not want to work. Following the instructions we push CLEAN, the 4 hour display comes on, we push START and the LOCK DOOR...
The oven self clean heats the oven in excess of 450 degrees. It will not begin until the door is properly closed and the slide lock goes completely home. This is to prevent anyone being able to get into the oven until after the cleaning cycle is done. When your "door lock" indicator blinks and beeps, try the door to see if it is really locked. If not, shut off the system and try to find out why it is not locking properly. If you find the reason and fix it, it will probably work properly.
Jan 01, 2018 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Code fse1 comes up when a few minutes after pushing start to cle
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,702 people viewed this question
Top Whirlpool Ovens Experts
Sal De
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
