Question about Protron PLTV-32 Television
PROTRON LCD 32'' TV
When I go to hook up my HDMI cable to my PS3 my TV picks up some of the signal but keeps flashing back and forth from no signal to the game what am I doing wrong or is it my new protron Hd TV.
  • Anonymous Apr 07, 2009
    I am having the same problem, the only work around I have found for it is to turn the TV off and back on again after starting the game. The display will stay constant after that. Atleast until you go out of the game. I know it's not a fix but it works.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Call Sony on the 800 number. I had that problem and I had to set the HDMI to a lower setting on the ps3. Also remember that all HDMI cables are not equal. If that cable is longer than 20 feet then you could have a weak signal problem.
Posted on Apr 17, 2007
    President:
  • 1,284 Answers
If your TV has a USB port or a media card input, then I would contact Proton for a possible software upgrade as this is most likely the issue.
Posted on Apr 12, 2007
SOURCE:
My tv is not picking up any hdmi signals from my ps3 and xbox. whats wrong?
The first step for this issue is to try a hard reset. Hook up the PS3 with both the Analog cable and the HDMI, set the TV to the Composite (analog) Input that you have chosen. Then, while the PS3 is off (red light), press and hold your finger on the power button for approx. 10-15 seconds until it beeps again. This will reset the PS3. After it turns back on, go through the set up steps, and after, it may tell you it has detected an HDMI connection, say yes and switch the TV to the HDMI input you hooked it up to. Click on yes before the timer ends and you should be all good.
Jan 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do you hook up a digital antenna to this tv? Protron PLTV3250 32" LCD
Connecting a Digital TV Signal
To connect an digital TV signal source to the
display, connect a coaxial cable between the
ATSC input and the TV signal source. GO to www.retrevo.com and download the manual,it is free.
Jan 10, 2010 | Protron PLTV3250 32 in. LCD Television
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Mar 30, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Hdmi does not work
go into TV menu and turn the HDMI on. guessing it should be in settings? or Video input.
Mar 07, 2009 | Spectroniq PLTV3250 32 in. LCD TV
32" protron tv
an output like ( HDMI ) would be on a dish reciever , and a hdmi input on a tv would plug into that output on the dish reciever
Is HDMI what you are trying to connect? then you would need an HDMI cable
HDTV = High Definition television , which means that you have a built in digital tuner that will pick up the digital and high definition broadcast channels with an antenna connected to the tv
Mar 02, 2009 | Protron PLTV3250 32 in. LCD Television
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No input signal hdmi
Are you on the correct video source on the TV
Feb 10, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
Protron PLTV-32 Television Logo
618 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
