I get a fan error on my roland camm1
It used to happen every once in a while we would just shut power restart and it was fine, now it does it constantly?
  • teri741 Mar 09, 2009
    Exact same problem and I know of another person that has the same issue.
  • Anonymous Apr 24, 2009
    same
2 Suggested Answers
  • 13 Answers
SOURCE: i'm looking for drivers for roland camm1 cm 12 for vista
driverguide lists the driver for windows vista
members.driverguide.com/driver/detail.php?driverid=33796&action=winfo
Posted on Aug 08, 2009
My Roland Camm1 cx24 not powwering up
I would first make sure everything is plugged up correctly.
If this doesn't work I would look into the power supply inside the computer and having it replaced. other than that I'm not sure how to help.
If you have any other questions or info feel free to respond and ill see if i can help
Jun 19, 2014 | Computers & Internet
My Roland G70 power up problem. .
Open up the Roland G-70 and check if all the connectors and flatcables are well seated. Check also if the power supply is working as supposed to.
Aug 30, 2012 | Roland Music
Shuts down after 5 minutes blinks green
Once the set shuts down, wait for the unit to stop blinking. Once it stops hold in the input and menu buttons for 5 seconds. The TV will then give you an error code. A 6-1 or a 1-8 error code would indicate a bad Color wheel. Which I think is the problem you have.
Jun 19, 2012 | Mitsubishi WD-65735 Television
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
This morning I tried turning my laptop on and it started fine, it went to the Dell Logo screen, but then it continued on and went to a black page with an error on it. Everything the previous day had gone...
Start and let it boot again and press F8 immediatly and use SAFE MODE to boot,
let the Desktop come up,
once stable shut down and wait for 3 - 4 mins
restart
Dec 24, 2010 | Computers & Internet
Computer does not fire up. I do have steady green light on power supply. All motherboard connections appear to be tight.I have come home before to a beeping noise in the past. After resetting the machine...
That beeping noise may be due to over heating.
Most machines today have a temperature setting that will turn the machine off once the temperature reaches a certain point.
Safety feature to avoid damaging your cpu and components.
The shut down and restarting allows the CPU to cool down briefly.
Thus allowing you to start the machine again. Usually it will shut down again once the temperature threshold is again reached.
Good test is let the machine sit for 30 min. If it immediately starts up and shuts down a few minutes later. Heat build is usually the problem.
Typically this is due to heat sink or Fan on the computer CPU.
Check to be sure both are connected to the CPU and functioning.
If you have a fan on top of the heat sink above the CPU. Make sure it is working correctly. Dust build up over time will eventually kill the fan bearings or reduce airflow. Heat sink can and will become clogged with dust also. Replacement fans are easy to find. Heat sinks are even easier to clean.
Depending on your machine and CPU position replacing the fan can be a challenge. But can be done in a few minutes with minimum tools.
Each bios has different post codes and it is difficult to tell what is happening with out knowing the bios of your particular machine. Listen for the beeps and check your computer manual.
You can also google for this. Here is a web site that lists a few bios P.O.S.T codes.
http://www.computerhope.com/beep.htm
Once you know the beep sequence you can look it up. Usually points to the problem and you can go from there.
Oct 06, 2009 | Computers & Internet
I'm looking for drivers for roland camm1 cm 12 for vista
Aug 08, 2009 | Acer Computers & Internet
Laptop Fan?
Before getting the fan replaced you may want to try to blow the fan with an air compressed duster. Worked for me. You do not need to take the laptop apart completely. There are 4 screws that holds the keyboard in place, unscrew the 4 and you should be able to pop the keyboard out. Once the keyboard is off you should be able to clean the fan.
May 13, 2008 | IBM ThinkPad T40 2373 Notebook
251 people viewed this question
k24674
Marvin
Marvin
